Post your Solid State pics here. - Page 332 - diyAudio
Old 26th December 2013, 06:25 AM   #3311
ostripper's Avatar
PERFECT !!!
OS
Amps: http://www.fidelityforce.com/ostripper
Quad core Athlon - Asus essence sound (PCM 1792A) - Slewmaster "Spooky Leach" 200W amp (final favorite).
Old 5th January 2014, 03:53 AM   #3312
Default My DIY effort
I'm a student in electrical engineering from Quebec, Canada and a few weeks ago, I completed these two projects. The first one is a F-5 from Nelson Pass. That wasn't that difficult given that the building guide on DiyAudio is pretty clear and easy to follow.
The second project is unique. It is a full function multichannel preamp. It has 4 input. A phono stage with enhanced RIAA curve. There is a Baxandall 3-band EQ for bass, mid range and treble adjustments. One input buffer (ne5532) and one output buffer. The output buffer is basically the B1 buffer by Nelson Pass. The input is selected by a rotary switch that activate relays. I also made the variable PSU that can goes from +/- 1.5 V to 37 V (1.5A). It is a typical circuit with just few changes(it has a very good ripple rejection of around 80 dB)...
The two PCBs has been conceived by me and everything is working fine.
The amplifier sound fantastic!!! =P
Old 6th January 2014, 10:12 PM   #3313
RCBandwidth's Avatar
Hi: That is certainly something to be proud of!...Great design and workmanship,The blue lighting effect is awesome
Bob C.
One man's magic is another man's engineering.
Old 6th January 2014, 11:38 PM   #3314
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Very nice and clean Mass!
2 thumbs up!
David
Old 6th January 2014, 11:55 PM   #3315
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by BobEllis View Post
Another Honey Badger is alive.
nice socks
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th January 2014, 05:12 AM   #3316
Aniket is offline Aniket  India
Aniket's Avatar
Default 250W+250W integrated amp
some pics of my new build. a 250+250W @4 ohm integrated amp, the main amp was designed by myself, PCB's designed by AlexMM, a simple soft start designed by me, protection based on Rod Elliott's design and the preamp based on Elliott's P97 preamp. Sounds fantastic. Bass punches in the chest with such an authority over the cone movement. Chassis is made at local sheet metal shop using 1.5mm steel.
Cheers!!!!
Aniket
Old 20th January 2014, 12:09 PM   #3317
Teti is offline Teti  United Kingdom
Teti's Avatar
Mighty beast almost finished, silver plated badges still to come.:banana:
Audiophile Vintage on YouTube | Facebook | Web
Old 20th January 2014, 12:50 PM   #3318
Marra is offline Marra  United Kingdom
Lovely work Teti.
Any internal shots?
Old 20th January 2014, 12:52 PM   #3319
Teti's Avatar
Thanks mate, I will get to it eventually. They standing on my DIY isolation base. Each amp 13.5 kg, isolation base 47kg
Old 20th January 2014, 12:57 PM   #3320
Solid then
Just found your thread om pfm.
Copyright 1999-2017 diyAudio
