Post your Solid State pics here. - Page 256 - diyAudio
Old 29th June 2012, 05:51 PM   #2551
osscar is offline osscar  Latvia
osscar's Avatar
well done Professor - nice wooden enclosure!
My JLH boards is still waiting when i solder them
My DIY : http://www.tutribi.net
Old 30th June 2012, 05:20 AM   #2552
amc184 is offline amc184  New Zealand
amc184's Avatar
My new phono preamplifier design. The case and controller PCB (the one at the front) are temporary while I finish the design.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 30th June 2012, 06:58 AM   #2553
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by kees52 View Post
here the sound, as a idea, youtube is not so well sounding........
thanks
best sound clip yet
but pics of amp not so good
Old 30th June 2012, 08:08 AM   #2554
rfj5106 is offline rfj5106  United States
Hello amc184. That is the most complicated phono section I have ever seen. Any chance you could explain what is going on in each board and what design philosophy you were using?
Richard Jenkins
Old 30th June 2012, 09:56 AM   #2555
Originally Posted by tinitus View Post
best sound clip yet
the sound reminds me, you have shown it before
reminded by the sound of a you tube clip
hehe, thats kind of funny
Old 30th June 2012, 10:06 AM   #2556
amc184's Avatar
The two stacked boards at the rear are the signal PCBs, each is one channel and has an MC amp, an EQ amp and a positive and a negative discrete regulator. The EQ stage has an adjustable filter, and can equalise LPs using the RIAA, AES, FFRR and NAB curves. Four of the reed relays are used to switch the filter, the other three select or bypass the MC stage. The 8-way DIP switch selects the cartridge loading and gain. The MC amp uses a LT1115, the EQ stage uses an OPA134 and BUF634 (I might change the OPA134).
The middle board is the power supply, and outputs four isolated 0-21VDC rails. They're connected on the signal boards to provide an isolated +/- 21VDC supply for each.
When finished, there will be a control PCB and a switch / display PCB at the front with an independent transformer and supply based on an Arduino Nano. I've not finished it though, so at the moment there's just a DIP switch, a regulator and a 9V battery to allow me to power the relays.
It sounds really good, especially with Deutsche Grammophon LPs using the AES curve. I gave it a good test last weekend using a Pro-Ject RPM9 with an Ortofon MC Rohmann cartridge.
Old 30th June 2012, 03:29 PM   #2557
337alant's Avatar
AMC184 thats an excellent job you have made of that phono
Did you design and build the PCBs yourself?
Alan
Old 30th June 2012, 09:40 PM   #2558
redjr is offline redjr  United States
Excellent! Looks great. It's obvious the attention to detail paid to your build. I'm sure it sounds as great as it looks.
Old 30th June 2012, 10:01 PM   #2559
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
best sound clip yet
Quality of pics doesn't matter!
Indeed, a very impressive sound!
Congrats, Kees!
Max.
Old 30th June 2012, 11:23 PM   #2560
amc184's Avatar
I did both the circuit and PCB design. I had the PCBs made by Seeed Studio ($65 for 10 each of all the PCBs in the photos) and assembled them myself. The case I had lasercut and bent by a local sheetmetal shop.
Copyright 1999-2017 diyAudio
