Old 26th May 2012, 01:37 PM   #2511
Originally Posted by luka View Post
why don't you use external site to upload pictures to
that's the problem (remote servers) that we should all try to avoid.
Old 27th May 2012, 02:53 PM   #2512
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
Today my new power amp the 'Ovation e-Amp' had its second outing. I played some Chris Botti (brass is always a good test!). I have put a few more pictures up on my website (just follow the link below). There is still a bit of work to do, but hopefully this project is finally coming to a close. 12 months of sweat.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 5th June 2012, 03:12 PM   #2513
masood is offline masood  India
Originally Posted by Mooly View Post
A poor pic part of preamp, the board at the bottom is a "hardware solution" to what should be done in software. The remote decoder is under the white plastic cover and I had to buy this in. Fully learning it will accept any "common" r/c commands, my pcb decodes the outputs and translates levels to operate fet switches.
this picture not seems of your single pair of mosfet 2sk1058 and 2sj162.thanks
Old 6th June 2012, 10:23 AM   #2514
Mooly's Avatar
Each of the metal cans is a complete power amp with its own pair of FET's.
For anyone interested the "cans" are from Sony C9 Betamax recorders and were ideally suited to the job. They were the SMPS enclosure.
The amp boards were sized to be identical to the original SMPS board and the FET's mount using the original hardware for the two 2SC2335L switching transistors. The actual heatsink is fairly small but is bolted directly to the perforated can which is around 2mm thick and very effective at dissipating the heat.
The DC offset protection board and DC input filters were also sized identically to the two other boards on each PSU.
It was an absolutely perfect one off solution for building the amps.
Original pictures here,
Post your Solid State pics here.
A simulation free zone. Design it, build it, test it.
Old 23rd June 2012, 10:58 AM   #2515
Default First try on SYMEF...
My first amplifier from this forum...
regards,
joel
Old 23rd June 2012, 11:02 AM   #2516
Default Randy Sloan amp.
my two OPTIMOS amp. running on 72v dc. A very reliable amp complete with protection and soft clipping.
regards,
joel
Old 23rd June 2012, 11:03 AM   #2517
Very nice. The internal heatsink solution looks very neat and efficient.
Inviato dal mio GT-I9001 con Tapatalk 2
Old 23rd June 2012, 11:07 AM   #2518
Originally Posted by Alexontherocks View Post
............The internal heatsink solution looks very neat and efficient.
I think the opposite.
Old 23rd June 2012, 11:53 AM   #2519
Default sloan basic EF...
this one is in my room and using it today.although it has no chassis but it is quiet.and it runs on a 36vdc with vi limiter. just the taught this would spice up the forum.
regards,
joel
Old 23rd June 2012, 04:17 PM   #2520
The best type of heatsinks would have been high efficiency 12cmx12cm extrusions with 2 fans tightly bolted on the extremities in push pull configuration. Hard to beat that configuration but the heatsinks are quite expensive.
For reference only
Obviously the extrusion must be closed on all 4 sides.
I still think the end result looks pretty neat. Imho of course.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
