Post your Solid State pics here. - Page 246 - diyAudio
Old 8th May 2012, 04:55 PM   #2451
redjr is offline redjr  United States
Looks impressive. That appears to be a Par Metal enclosure?
Old 8th May 2012, 06:07 PM   #2452
tangmonster's Avatar
Originally Posted by AndrewT View Post
What fuse rating does that allow reliable start up every time?
Does that fuse ever blow when the music is turned up to silly "party levels"?
What size of fuse did you finally select?
Haven't decided on a final fuse size. Heck i haven't even soldered the rca wires on yet :P
So far just bench testing. And letting it idle for long times checking the bias.
Currently I have a 7.5 Amp slow blow in it.
The enclosure base and lid is 1.6mm mild steel black powder coated and the face is 4.5mm natural anodized Alu. The faceplate is punched to keep costs low. (around the $100 for the entire case with faceplate if I can convert it to $ directly)
I designed this enclosure (135mm high 420mm wide and 300mm deep) and a few other sizes ( 95mm en 60mm high) for the South African Audio video forums as a group buy.
Old 9th May 2012, 03:22 AM   #2453
Good job. It looks very similar to the enclosure I used on my latest build, and the cases supplied by Par Metal here in the US.
Old 9th May 2012, 10:15 AM   #2454
T7.5A is no protection at all.
That should start a 500VA without a soft start (500VA / 230Vac * 3 ~= 7.5A)
Soft start allows the 3 factor to be reduced to ~1
I would expect a 500VA to soft start on a T2A fuse and you may find that you can start and operate your amplifier with a T1.2A or T1.6A. That's why my first and third questions look similar but are actually asking for different information.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th May 2012, 10:24 AM   #2455
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
A nice solid build tangmonster! Baie lekker ek se!
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 9th May 2012, 10:40 AM   #2456
Since I have 2 x 500va toroidals (each supplying a voltage rail).
I agree a 4 amp fuse will probably be good.
No reason to see how long a 3.15Amp fuse will last tho....
I'm sure I have some T3.15's so i'll try them next.
First I need to finish wiring...
Old 9th May 2012, 10:42 AM   #2457
Fuse each transformer separately.
The chances of the fault causing both to draw fault current at the same time is virtually impossible.
regards Andrew T.
Old 9th May 2012, 01:30 PM   #2458
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Bonsai View Post
Baie lekker ek se!
You should say it more often, Mr Russell.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 10th May 2012, 08:22 AM   #2459
JLH all finished
Old 10th May 2012, 08:57 AM   #2460
Telstar is offline Telstar  Italy
Change the RCA cable please
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Copyright ©1999-2017 diyAudio
