Post your Solid State pics here. - Page 242 - diyAudio
Old 1st May 2012, 02:16 PM   #2411
AndrewT is online now AndrewT  Scotland
Red for ON seems wrong.
Red for danger, maybe.
Red for something gone wrong seems unambiguous.
Grn for OK, or ON seems far better.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st May 2012, 02:16 PM   #2412
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
Originally Posted by SoIL4x4 View Post
DjQuan, what did you use for clear coat? It looks great
we posted on the same time lol
I used ordinary clear coat from spray can. I think it was acrylic
edit:
Originally Posted by AndrewT View Post
Red for on seems wrong.
Well, the red looks ok to me on contrast with the brushed aluminum and black switch. I no longer like blue because everything seems to use blue led nowadays. I haven't tried green though. If I'd go green, I'd use the true green ones not the yellow green. I'll give them a try next weekend.
Old 1st May 2012, 02:42 PM   #2413
redjr is offline redjr  United States
Originally Posted by djQUAN View Post
Thanks redjr.
I attached the last pic I took with everything completed inside. It actually sounds pretty good even with jellybean parts used. When the higher quality parts arrive from digikey, I'll take the boards out again and replace them.
I'm actually torn on the power switch LED color. I can't decide to retain the red or change it to white. I also attached pics on how they look with red and white.
That's a sweet looking layout. Either LED color looks fine. I guess it's just a personal thing. You could always go blue as I did (below). It looks much brighter and has that star-burst appearance because of my camera. I went with blue simply because I had built a couple other pieces that used blue so I continued to follow that theme. I could lower the brightness by adding a resistor thus lowering the voltage, but right now it doesn't bug me.
Old 1st May 2012, 02:47 PM   #2414
That chassis looks nice, got more pics of your amp? What design did you build?
If it was 5 years ago, I wouldn't think twice and grab a blue and drop it in. I guess I got over the blue craze now lol
BTW, If you'd like to see more pics/description of my amp, you can see the build log page I made here: P101 Amplifier
Old 1st May 2012, 03:12 PM   #2415
FastEddy's Avatar
Red for ON seems wrong. ... Grn for OK, or ON seems far better.
And green LEDs are so cheap and plentiful ... Blue or near white are more, but not that much anymore.
I always liked an LED - VU meter as a pilot light ... But anyone know where to get these ... Or is DIY better
Old 1st May 2012, 04:35 PM   #2416
I just finished up mine about a week ago, and ended up redoing my input cabling due to a ground loop. My build is chronicled here. You can also find more detailed pictures on Photobucket here.
I cheated a little bit and decided to go with some pre-built modules I found on eBay. I used a module built around the LM4702 and decided to just go with the stock parts for my first attempt. Nothing exoctic here. I worked with a vendor in China, who was very helpful as I needed to communicate with him via email - despite the broken English. I know it's an aging chipamp now, but I'm very happy how it turned out. Maybe I'll be a little more daring on my next build and attempt it from scratch! The build quality of both the amp and PSU are very high IMO. Mine's rated at about 100wpc for the voltages I'm using and really does sound sweet. It's not in full service yet, and has yet to be hooked up to my main, vintage listening rig. I was away at a graduation this past weekend. Maybe this week. It's time!
I'll take a look at your link too. Always fun to see how someone else approached their build.
Old 1st May 2012, 06:51 PM   #2417
Arius is offline Arius  United States
Here's mine. Version 2 of my Class AB ThermalTrak power amp module. Version 1 was posted sometime in 2005 (too many projects, haha).
PCB is 250mm X 75 mm.
Nothing exotic but decent parts used throughout....
4 output pairs for up to 200W/8R output (100W as shown)
100V 105C high temp low esr electrolytics
Silver mica caps for the high freq caps
Wima film caps for decoupling
Mills MRA05 low inductance emitter resistors
Onboard output delay, dc sensing and thermal shutdown
Keratherm White 86 thermal tape
Power and Output connectors are locking Molex Minifit Jr types. Screw/spade terminals are a big no-no here at work. LED color is not mentioned, heh.
Pictures:
1) Overall picture of board
2) Input/VAS detail showing how input TO92 pairs and VAS cascode pairs are thermally connected
3) Output stage showing individual base resistors and Wima 0.68uF MKC decoupling cap
Old 1st May 2012, 07:39 PM   #2418
That's a nice looking, quality PCB and parts Arius. Was all of it from scratch? Is that PCB still available?
Old 1st May 2012, 08:28 PM   #2419
After long time I see here quite precise work of man, which really knows own work, which have it also like hobby...Bravo, Arius!
Old 2nd May 2012, 09:59 AM   #2420
Redjr,
this is the pics Thread.
Attach your pics here.
Save the description and build details for another more appropriate Thread
regards Andrew T.
Copyright 1999-2017 diyAudio
