Post your Solid State pics here. - Page 185 - diyAudio
Old 31st May 2011, 11:59 AM   #1841
Originally Posted by Mooly View Post
Thats good... did you use Diptrace to do the PCB by any chance ?
Very neat
The layout is done in Eagle, DRC was set on min 10mil between tracks.
I misread my drillbits and drilled most of the holes with a .9mm drill when I thought I was using a .6mm one...
I tried getting the board under 5x5cm(seeedstudio, 9.90$ for 10 pieces) but there was no way that was happening. Not that I would order it anyway, I just enjoy the challenge. Finished design will be a bit bigger, with mounting holes and horizontal resistors.
Kolbjørn
Old 31st May 2011, 03:27 PM   #1842
Hi Cheers
can you uploade the .LAY file of Nmos350 Recommended Power Supply ?
i want use that circuit for my nmos200 circuit and i need to change it.
sorry for my English
bye
Old 4th June 2011, 03:54 PM   #1843
Captain archer's Avatar
Send a message via MSN to Captain archer
Default New Gold Member
Last year i finished my new amp.
It is a shiny 2x18 watt retro influenced solid state amp.
Every transistor is from the late 60's but the circuit is more like the blameless amp from Douglas Self.
It has a build in RIAA correction amplifier for Vinyl playback and 2 additional inputs for CD or Ipod etc.
The whole thing is designed and simulated in Multisim 2001 and build on experimental (vero board) print that has been painted Black.
Works like a charm and sounds super smooth, I really like it.
And the modest 2x18 watt is more than enough for me.
Hope you guys like it.
Old 4th June 2011, 04:53 PM   #1844
Mooly's Avatar
Very neatly done
Old 18th June 2011, 12:42 PM   #1845
No picture, but bought an Onkyo push pull with WRAT technology, model # TX -NR3008, hasn't been shipped yet and last one available unopened box. I also bought a 15 amp powercenter and I need to replace wiring and put a 20 amp fuse for high amp digital circuitry protection and a 20 amp fuse for high amp analog. I lost old username, etc. I've been sick for 4 years and my computer was destroyed by people I thought were friends, or else I'd be still posting with old username, etc. Please, I blew my B&K AVR507 updated to V3 and everything is explained under solid-state, but haven't been able to have post's posted, because a moderator needs to see if I'm a home theater nerd, or a for real DIY audiophile junkie, which my old posts would prove, so I understand and need to go to doctor's appt, so I'm posting and reposting as to let mod see I'm for real, but need to go. Thanks for your time.
Old 25th June 2011, 11:25 AM   #1846
masood is offline masood  India
dear sir,can some one display the nico ras amplifier 2sk1058 and 2sj162 based amplifier picture gallery ,thanking you
Old 29th June 2011, 01:34 PM   #1847
osscar is offline osscar  Latvia
osscar's Avatar
This is my second Leach amp -just finished.
Sounds good. Some of internal wires has not yet been arranged and enclosure cleaning still needed.
DC offset - 16mV and 3mV. 20Khz square wave you can see in photo.
Transformer 350VA. 6x4700uf per rail. No hum - measured about 0.05-0.08mV without shorted inputs.
Transistors from original article. bias- 100mA.
My DIY : http://www.tutribi.net
Old 29th June 2011, 03:36 PM   #1848
ostripper's Avatar
Awesome leach build , MUCH better than most. Triple OP is the only way to go, took me over 2 years to realize this.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 29th June 2011, 03:41 PM   #1849
stoN_Cold's Avatar
Chassis from Russian amp
Regards zeoN_Rider
Old 29th June 2011, 03:50 PM   #1850
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
very clean and well thought out osscar , good work.
Copyright ©1999-2017 diyAudio
