Old 22nd May 2011, 10:42 PM   #1831
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Thanks! Very clever approach to save space.
All the best, Max.
Old 23rd May 2011, 12:56 PM   #1832
apexaudio's Avatar
APEX SR200 made by 'macd'
Old 23rd May 2011, 01:01 PM   #1833
smartx21's Avatar
Originally Posted by alex mm View Post
..... pictures at request ...
Maybe some guys will advice you to invert downwards the L-shaped alluminum adapter, so to better dissipate heat through the large heatsink.
Is that a dual-winding transformer?
All the best, Max.
Old 24th May 2011, 01:42 AM   #1834
wmincy is offline wmincy  Malaysia
alex, wow, neat design!!
the fever of DIY HI-FI will NEVER be cured !!!!
Old 24th May 2011, 11:18 AM   #1835
very definitely.
There are two advanatges to inverting the L angle.
1.) the heat transfer interface is moved down towards the optimum height for heat dissipation (~ 40% up from the bottom)
2.) The output devices can be mounted much closer to the heatsink, significantly reducing the thermal resistance of the thin horizontal leg of the L.
There is a small advantage to mounting the To3s on the outside of the L. The inside face will be non-flat and extremely difficult to be corrected to flat. The outside face of the L is also likely to be non-flat but these faces can much more easily be corrected to flat, or at least flat enough.
Old 29th May 2011, 08:28 AM   #1836
Banned
Here's my Borbely 894/211 Clone.
and my Pumpkin / Shuntky
all being built to compliment what will be a DIY-PASS F4
Andy
Old 29th May 2011, 04:11 PM   #1837
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Andy
airplane or heli radio box in the background
Old 30th May 2011, 02:50 PM   #1838
cyberspyder's Avatar
Send a message via MSN to cyberspyder
Shoes actually. Boots if I'm not mistaken
Brendan
Old 31st May 2011, 06:54 AM   #1839
Might as well throw the pictures in here as well.
This is my first prototype of a headphone amp, only one channel atm. Still learning the ropes of solid state. Amp does work fine after all the kinks were worked out.
Running only 2n3904/2n3906 and MJE3055/MJE2955. Will try other alternatives in the next version.
Kolbjørn
Old 31st May 2011, 07:47 AM   #1840
Mooly's Avatar
Thats good... did you use Diptrace to do the PCB by any chance ?
Very neat
A simulation free zone. Design it, build it, test it.
Copyright ©1999-2013 diyAudio
