Old 1st May 2011, 03:49 PM   #1811
kct is offline kct  Canada
kct's Avatar
Very nicely made. Please post more pictures of your progress.
Here is another beauty shot of mine...
Cheers
Old 1st May 2011, 05:46 PM   #1812
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
Far Side
Old 2nd May 2011, 06:19 AM   #1813
ostripper's Avatar
The "far side" ..... nice neat , compact SMD. Run dem babies , I wanna see a 120V p-p squarewave w/ 1uS rise
Oh , I feel so primitive I just had to enjoy a big glass of " vino" . I guess "no fine wine before it's time".... same with the DIY PCB's (below 1). First pair work fine , but have a slight thermal "issue" (but not a burning amp). Hopefully, this pair will work as good as they sound (thermally). I must fill that glass half way up to be truly subjective.
PS - PCB's are:starting left.... 2 X nikko PB120's (corrected version) and 2 X EX1.2 voltage stages (goldmund inspired). 1st PB120 is powered to test cap MUX'es. (below 2/3) the AX - being abused at 10Khz 60V p-p.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 4th May 2011, 10:53 AM   #1814
fotios is offline fotios  Greece
fotios's Avatar
OS
Nice score ostripper! Looking at the oscilloscope picture, my estimation is a rise time between 0.9 to 1.2μsec.
I would like to see a picture of your PCBs from the solder side.
FOS
Best Regards FOTIS ANAGNOSTOU
Direct Contact: eal@dra.forthnet.gr
Old 6th May 2011, 07:20 AM   #1815
ostripper's Avatar
Red face still 1 board away.
(below 1) is the solder side of the soon- to- go thermally unbalanced, but awesome sounding Nikko pb120's.
(below 2 - big board) is what I will have to do to get rock solid 60ma/device operation (fully separate heatsinks per amp). Nikko must of used ultra matched sankens + no base stoppers to get at least a close balance of idle current per device. Even in it's imperfect state , the amp can be pushed all day rail to rail with no issues. Unfortunately , I am a "perfectionist".
I will show the whole thing in a week with the "big board".
OS
Old 6th May 2011, 03:41 PM   #1816
Default Problematic Kenwood Super Eleven
I found it curbside.
Old 6th May 2011, 05:57 PM   #1817
ostripper's Avatar
Fix it (schema attached) , it's a "pretty" receiver. Recap the power board , regrease the outputs (or replace with mj15003/4). If you were to make a new amp for it , design the PCB to be a exact replacement (no drilling). looks like the kenwood has a good, simple LIN topology EF2 AB amp with TO-3 outputs ... 55-0-55V PS ... typical.
OS
Old 6th May 2011, 09:02 PM   #1818
OS
Ostripper:
Thanks for the information. I looked at replacement capacitors when I first found it. I admittedly need to get better with a soldering iron. Don't want to burn down the house.
Old 12th May 2011, 05:45 PM   #1819
ostripper's Avatar
Default Time for "fine wine" (California ?)
Finally it's done... What a PITA to redo a Nikko , no wonder others never concluded the job.
(attachment 1) is the wine /bottom , wired in the classic Japanese hi-fi style.
Yellow led is the main speaker relay board (protection to come soon)
(Attachment 2) is the top view , 2 PS's (65-0-65V and 58-0-58V) , nice and tidy.
(Attachment 3 ) is how I got this far , had to make a special board or go for bust. Each amp has it own heatsink , 10C - 35C / 13-14mv (60mA - all OP devices) ... perfect Vbe. Sound is VERY detailed , quite the punch .. as well !!
OS
Old 12th May 2011, 07:21 PM   #1820
Default That is very cool
OS
I first heard the Nikko line in the 1980s, when I was in college. Good stuff. You've gone the extra mile on that amplifier, ostripper.
Hoya Fan
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
momo blast
Page generated in 0.20935 seconds (35.39% PHP - 64.61% MySQL) with 11 queries
