Old 5th August 2010, 03:01 PM   #1521
lanchile's Avatar
Originally Posted by andrewlebon View Post
hi biyiers
greetings my 2.1 amp winding my toroidal primary complete my aluminum cabinet with usb input 2.1 amplifier 300 watts each + 600 watts 2 channels bridged
thanking you
Andrew lebon
That is a nice monster there! The transformer looks like a commercial one Very well build. Nice job.
Old 17th August 2010, 11:39 AM   #1522
YouTube - ADCOM GFA555 UPGRADE
Old 24th August 2010, 01:47 AM   #1523
amc184 is offline amc184  New Zealand
amc184's Avatar
This is my new phono preamp. I designed it for playback of a friend's LP collection, it can equalise records with the RIAA, AES, FFRR and NARTB curves. It uses both series and shunt regulation to feed a single opamp based gain stage with an active filter, including a BUF634 current buffer to allow the opamp to drive the capacitive load the filter presents.
Old 24th August 2010, 08:41 PM   #1524
Default New JLH class A headphone amp
Hi
Please find my newly constructed JLH class A headphone/preamp. The unit has a remote control volume control and will be upgraded with better op amps soon. The unit sounds 1st class, it also has passive and active line out.
regards
JamesFeline
Old 26th August 2010, 09:55 AM   #1525
A square's Avatar
Send a message via Yahoo to A square
Originally Posted by lineup View Post
Nice work, Milan
Academia PCB mounted:
Everybody!
Make a visit to moamps wonderful website!
He has got many amplifiers images. Solid State Amps & Tubes Amps.
You will like it ... for sure
http://www.moxtone.com/
INSIDE CASE Top View - of his Academia Amplifier
lineup has got several good internet friends from Croatia
edit:
.... and I wouldn't be very surprised
if it turned out that me lineup has got something to do with
Tube with Power IC Output Stage-JLTi - topic
Replies: 895 ..... Views: 126733 !!!!!!
hi sir can u give me pcb layout nd circut of it ..?
Old 27th August 2010, 06:25 PM   #1526
ostripper's Avatar
This is not twitter !! grammar counts.
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 27th August 2010, 06:37 PM   #1527
regiregi22's Avatar
Wow, really georgeous. Can we see a picture from the top? I'm specially interested in how can you have fitted a series regulator, a shunt regulator and the equalization section in such an small place!
And a very convenient button to isolate it from earth
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 27th August 2010, 10:38 PM   #1528
amc184's Avatar
I can send you the schematic (send me a PM), it is based on a design by Walt Jung, published in his book 'Op-Amp Applications'. I took his topology, but applied different power supplies, different active devices and an adjustable Lipshitz network.
I gave the phono its first proper test last night, and it was great to finally hear AES, NARTB and FFRR vinyl with its proper EQ curve.
I don't know what you mean by that, there's no ground lift button.
Old 28th August 2010, 08:52 AM   #1529
regiregi22's Avatar
Sorry, I was referring to James Feline amplifier when referring to earth lifting
Yes, some schematics would be really helpfull. I would really grateful to see the design
Old 2nd September 2010, 02:04 PM   #1530
mauto is offline mauto  Italy
My work : Gainclone LM3875
Copyright ©1999-2013 diyAudio
