Old 4th February 2010, 09:04 AM   #1281
Hi shaan,
there is one piece of a yellow film cap on each of your pcb's (I think it's 470nF, 63V). Can you tell me what brand this is? I also have two of those (in 2,2uF, 63V) which I desoldered from another device, and I would like to know who made these caps.
Thanks!
Martin
Old 4th February 2010, 11:19 AM   #1282
shaan is offline shaan  India
shaan's Avatar
Hello Martin.
I don't exactly know who produces those yellow caps. I have been told by the retailer that these are MKP polypropylene caps and are excellent for use in audio path. I did ask him about the manufacturer many months ago but it seems he doesn't know it either. Now as you have reminded me of this, I think I will go ask experts in other hot forums and expect I will get the name.
thanks.
shaan
LESS "THINGS", MORE LIFE
Old 4th February 2010, 11:53 AM   #1283
Hello shaan, thanks for your efforts!
Mine are from the signal output of a Moodlab Concept DAC. I changed them for BG N's, but recently I compared them to other MKP's and I found them to have a quite unique sound signature, which could be just the right thing for certain applications. But to use these caps would only make sense if they would be available to anybody in different values for different projects.
Regards!
Martin
Old 4th February 2010, 11:56 AM   #1284
shaan's Avatar
Hi Martin.
These caps are indeed available in a long range of values. Well, that still remains from about 0.01uF upto about 10uF, above which I haven't seen one yet.
Old 8th February 2010, 06:42 PM   #1285
Default Velleman amp
Hi All
please see my velleman amp that I have just made. The front is laser engraved and the tigers eyes light up when the power is on. Sounds good to my ears. what do you think?
Old 9th February 2010, 02:36 AM   #1286
Bonsai is offline Bonsai  Taiwan
Looks good. Does it hum?
bonsai
http://www.hifisonix.com/
Old 9th February 2010, 03:41 PM   #1287
Default k4005
Hello
not at all, sounds very good with no hum. The only issue is that the amplifier can shut down when pushed to hard. I can adjust the current monitor resistors in the feedback system, to solve this. but otherwise I was very surprised with the quality of the sound.
regards
Nick
Old 9th February 2010, 07:31 PM   #1288
Telstar is offline Telstar  Italy
Hi Fotios, beautiful work
Originally Posted by fotios View Post
The problem with Modu it is that although it offers enclosures with very impresive front panels (10mm thick! alu) and very nice handles, the rest pieces of enclosure are: top and bottom covers from metal plate and the back plate from alu 1,5mm thick. In mine amplifier the covers are from 3mm thick alu plates which are screwed very tightly and directly on heatsinks (see in pictures) and offers significant assistance in heatsinks in heat disipation.
You can ask for alu panels (not sure the thickness), at (high) extra cost.
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 10th February 2010, 10:01 AM   #1289
shaan's Avatar
Regards!
Martin
These caps are from Shenzhen(china). Available from 0.003uF upto 1uF. Two tolerance varieties; J and K.
J = 5%
K= 10%
cheers.
Old 10th February 2010, 10:11 AM   #1290
Thank you shaan for the information!
I've another dac here from china which also has lots of these yellow caps on its pcb, I guess this brand is something like the chinese equivalent to Wima here in germany.
Regards!
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
momo blast
Page generated in 0.14149 seconds (71.28% PHP - 28.72% MySQL) with 11 queries
