Post your Solid State pics here. - Page 11 - diyAudio
Old 26th May 2007, 08:39 PM   #101
lineup is offline lineup  Sweden
lineup's Avatar
Default lineup solid state dsicrete 3 pin regulator
A follow up to my Post #14 in this topic.
Where I show a close up of my most advanced headphone amp circuit.
You can see itin this Image Attachment:
http://www.diyaudio.com/forums/attac...amp=1171426328
This time,
I will put ..... a small very precise 3 pin regulator
built with 3 TO-92 transistors + some diodes for voltage reference.
Intended use: Powering Op-Amps in battery powered gear.
Data:
Circuit own power consumption: 150uA ( 0.000150 Ampere )
Voltage output: +5.000 Volt ( +/- 0.010 Volt = 10mV )
Max current output: ~50-100 mA something
(but few normal audio Op-Amps would take more than 10mA per IC)
Dropout Voltage: ~0.050 Volt max (at 'normal' 15-25mA output)
... gives ...
Minimum input voltage( for +4.99V out): 5.04 Volt DC ...
As said, this regulator, in it self would take, draw, only 0.15 mA to work properly.
So it would take many months to empty your batteries.
The hardware use the same typical ' lineup costruction method '
= hardwire at the bottom side of a piece of pcb experiment board.
In this case, it required like 25x25mm (1x1 inch)
See image attached here below.
It is easy to see my 3 brown pins in the corners of my circuit:
1. input pin
2. ground - 0 Volt pin
3. output pin
Regards and happy viewing my nice picture!
And my good design works!
lineup
File Type: jpg lineup-regulator_low-drop-and-consumtion.jpg (74.0 KB, 7643 views)
lineup
Old 27th May 2007, 06:27 AM   #102
PMA is offline PMA  Europe
PMA's Avatar
Hi lineup,
I have always loved your breadboarding. It reminds me my schooldays, when I started with electronics.
Go on!
Pavel
Old 27th May 2007, 08:10 AM   #103
PMA's Avatar
Here is the final view. The turntable (below the amp) I bought in 1972
Old 27th May 2007, 09:38 AM   #104
lineup's Avatar
Originally posted by PMA
Hi lineup,
Go on!
Pavel
Here you have my discrete regulator data again .. in case somebody did miss it.
Transistors are BC550C and BC560C .. no other could do this job better, at such price.
A Feature worth mentioning:
Reference diodes, see picture: 1N4148 + Green LEDs
This reference is powered, biased
from my very precise OUTPUT ( +/- 0.01 Volt )
This feature, of course, improves
Regulator Line Regulation enormously!
Think these data deserves to be noted:
Data:
Voltage output:
+5.000 Volt ( +/- 0.010 Volt = 10mV ), accuracy +/- 0.2%
Max current output:
... gives ...
5.04 Volt DC ...
... those figures can take a compare
against 97.5% of all commercial chips out on the market
lineup
[color=sea-green]PMA
You use your turntable?
I have plenty of very good old LP vinyl albums.
Have been thinking of
- Build myself a good discrete RIAA amp
- Upgrade my Pickup to something nice
- Start copy my analog LP Records to Digital CD
..... but typical for me is this thinking:
"Hmm, there is a day tomorrow, too.
I will do this Vinyl Project later
[/color]
... and as we all know, tomorrow ALSO has got a day tomorrow ... => into infinity
but for us, human souls, comes a day, sooner or later,
when there is no more tomorrows
Old 27th May 2007, 10:15 AM   #105
PMA's Avatar
Hi lineup,
yes, I still use my turntable with Shure cartridge. The RIAA pre is active, based on 2134. And I have a nice collection of LPs, and time after time I buy new presses in 180 grams.
I am afraid that digitalization of LPs makes the worst of both worlds, containing disadvantages of both media ... you get LP noise + digital sound (low sampling speed, bad digital filters and HF residuals).
Pavel
Old 31st May 2007, 10:42 PM   #106
suzyj is offline suzyj  Australia-Aboriginal
suzyj's Avatar
Default My little power amp
Here's my entry:
Dual mono lateral MOSFET amp, with JFET input stage and mainly SMD construction. Each channel is good for 140W RMS into 8 Ohms. 0.0013% THD (1KHz, 100W into 8 Ohms).
It's been running for a goodly few months now, with its matching preamp. I still haven't gotten around to building a muting circuit for it though, and it's still without a front panel
It sounds good though
Old 31st May 2007, 11:50 PM   #107
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Re: My little power amp
Originally posted by suzyj
Here's my entry:
Looks very nice, who's design ? Good job
Old 1st June 2007, 04:57 AM   #108
suzyj's Avatar
Default Re: Re: My little power amp
It's an updated version of David Tilbrook's AEM6000. See http://www.littlefishbicycles.com/poweramp/index.html for details.
Basically I used his topology, but updated a many of the transistors, then used spice to optimise everything to get the distortion figures down.
Old 1st June 2007, 06:07 AM   #109
PMA's Avatar
Very nice job, Suzy
Old 1st June 2007, 06:15 AM   #110
Banned
Default Re: Re: Re: My little power amp
What simulation software did you use if i may ask ?
I'm learning Electronic Work Bench, but the library files are not that large, i can;t get IRF fet's and other things that i'm used to using.
Great chassis work and good layout. Protel is nice..
Jase
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
