#91 |
Hi lineup,
actually not much space left, dimensions are 38 x 22 x 7 cm (15" x 8.7" x 2.75" - for US readers), and 225VA Talema toroidal transformer inside. |
#92 | |
It is very good and clear construction. I have only one question. The power transformer and the PCBs don’t need ventilation? I don't see airing slots (notches) or holes in the top cover. Fotios |
#93 |
You are right, they do not need vent holes. In this specific case. I do not try to generalize.
#94 |
My all JFet line stage pre-amp.
#95 |
The one and only
Good show!
#96 |
Banned
#97 | |
Very nicely built! BTW, you do like exotic topologies, don't you. (nothing wrong with that!) Cheers, Edmond.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#98 | |
Great Solid construction - and using Master Nelson's circuits. Bi-amping is the Ultimate Way! Many good things from true, 2 amplifiers per loudspeaker, biamping. This is my final goal: - Build 2 two-ways loudspeakers - Drive each woofer with it's own Power amplifier = 4 endstage mono amplifiers Maybe some day come true .... I hope. One simple way, is to build it using 4 x LM3875 National Power IC amps. These modules are put inside loudspeaker box. Then I need one stereo preamplifier with volume control and some signal cables to feed loudspeaker + amplifier modules. And a clever way, to switch POWER ON to my complete setup. If dreams could make wishes come True - this is what I would really would do Regards - and thanks for your nice image, jleaman lineup Lineup Audio Labs
lineup |
#99 | |
basically, yes. Semptember 1995 issue, Fig.2. R3 and R4 resistors are replaced by current sources, that are connected to supply rails. This has improved noise background at lower frequencies and stability. The opamp voltage gain stage is placed in front of the original circuit and the output stage gain is reduced to 4x. There is a global NFB. And yes, I like the bright circuit ideas Regards, Pavel |
#100 | |
Banned
Thank's for the kind words :P Im bi-amping these : and switching between these.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| momo blast |
| Page generated in 0.14613 seconds (75.79% PHP - 24.21% MySQL) with 11 queries |
