Post your Solid State pics here. Post your Solid State pics here. - Page 70 - diyAudio
Old 29th January 2009, 01:40 PM   #691
megajocke is offline megajocke  Sweden
megajocke's Avatar
Yes, very nice!
How did you make the case and how thick is it? Are the power transformers mounted to the front panel?
Old 29th January 2009, 04:21 PM   #692
thunderpld is offline thunderpld  England
Btw what are the output transistors?
Old 29th January 2009, 07:49 PM   #693
wg_ski is offline wg_ski  United States
Case is made the same way all of mine are. 0.125 or 0.090 sheet aluminum stock, cut into panels. Bolted together with angle aluminum. This particular series used a perfab 3U steel rack panel for the fronts - and yes, the trafos are bolted to the front panel.
Output trannies are the MJ21193/4. There's a total of 20 plus drivers. There are two heat sinks stacked on top of one another, with the 4" 105CFM fan blowing through them. Exhaust holes are in the top of the case. The circuit is posted in the "700 watt amplifier" thread, which is buried somewhere by now, and brought up again recently when another member got interested in Project 117. As you can see, this similar amp is finished and has been working in the field for some time.
Old 6th February 2009, 12:19 PM   #694
tmyr is offline tmyr  Greece
Default The "Dimitra" Amplifier...
Hallo to everybody !
..this is my realization of a PtP n-hexfet stereo amp ("The Saint" 's design.. thanks man.!) with 1 pair of industrial 60Amp peak current fets & ecc83 triode buffer per channel, @ +/-33v rails, fused protection, soft start delay, descrete geared attenuator pots, a balance pot (hi-fi style) & 6 input selector+rec out, hand made to the bone.
Old 6th February 2009, 12:25 PM   #695
..some more fotos ..
Old 6th February 2009, 12:46 PM   #696
just one attacment per post limit here..
..back side..
Old 6th February 2009, 12:49 PM   #697
..up close detail..
Old 6th February 2009, 12:59 PM   #698
..and the all favorite 'top cover missing' foto..
Old 6th February 2009, 01:03 PM   #699
..ok just one more.. the one i call 'train engine'..
..it sounds great .. the detail through my diy ecl's is spectacular, sweet, tube like sound & distortion at hi levels, no hot spots inside so ventilation holes ,no pcb except for holding the caps & rectifiers...
Old 6th February 2009, 01:07 PM   #700
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
tmyr,
that is one cool looking amp! congratulations!
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Post your Solid State pics here.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
