Post your Solid State pics here.
Old 25th October 2015, 09:32 PM   #4351
redjr is offline redjr  United States
Originally Posted by smartx21 View Post
What was there inside that Nescafé cup?
Coffee?
redjr
Old 25th October 2015, 09:34 PM   #4352
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Post your Solid State pics here.
Originally Posted by redjr View Post
Coffee?
Sure, but hope not soluble. Would not look good beside that beautiful amp.
Max.
Old 25th October 2015, 09:50 PM   #4353
I agree. A little too close for my comfort, but to each their own. My liquids are always kept at least an arms length away. No jewelry either when around electronics. Learned that from an old Navy tech about 45 yrs ago.
redjr
Old 25th October 2015, 11:27 PM   #4354
mhouston is offline mhouston  Australia
mhouston's Avatar
Originally Posted by vzaichenko View Post
OK, it's already described in CF-FET thread, here are just some pictures.
Starting from the front-end PCB and early prototype testing, and ending with a finished "product".
I'm using it as a main power amp in my audio system now
Great build.
Old 26th October 2015, 12:28 AM   #4355
timbarnes is offline timbarnes  United States
timbarnes's Avatar
Default Rod Elliot P101 build
Inspired by Burning Amp, I just finished my new power amp. This is Rod Elliot's design, with his soft-start board and a diyaudio power supply board.
Shockingly clear and analytic so far with my (ridiculously efficient) Pi Seven speakers.
The case is not what I would like aesthetically, but for now it does the job. The metalwork is part of an earthing network that terminates in a star by the IEC socket and at the output end of the power supply.
tim
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Moode, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 26th October 2015, 12:37 AM   #4356
tim
Neat.
redjr
Old 26th October 2015, 12:46 AM   #4357
timbarnes's Avatar
Thank you. The heatsinks are ridiculously large - they are barely above room temperature. I might wind up the bias a bit to see if it makes a difference.
Maybe next time I want to build an amp I'll saw the heatsinks in half...
tim
Old 26th October 2015, 12:51 AM   #4358
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Here are my three Maplin amps from the 1980's.
Left hand side is 225WRMS bipolar amp using 2n3055 and mj2955.
Top right is bipolar 50WRMS amp.
Bottom right hand side is 75WRMS mosfet amp.
I bought the first two off ebay faulty and repaired them.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 26th October 2015, 04:28 AM   #4359
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Originally Posted by still4given View Post
Looks like the front heatsinks are just to for looks. I'm too cheap to do that. I would have to find something to mount on them. Beautiful amp!
Well, the heat still distributes to the front sections, however they are definitely less warm than the back ones. This is a result of not enough thinking when arranging the PSU
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 26th October 2015, 04:31 AM   #4360
vzaichenko's Avatar
Originally Posted by jacco vermeulen View Post
Even more ironic when you follow the route/wire from the output coil to the output terminal, Terry.
Very valid observation Already thinking about moving the relays right to the output terminals (and probably switching to the SS ones)
http://vzaudio.com/
Post your Solid State pics here.Hide this!Advertise here!
