Post your Solid State pics here.
Old 23rd July 2014, 04:43 AM   #3591
egra is offline egra  Hungary
egra's Avatar
Originally Posted by borys View Post
The new amp is on the way. I think I will never finish any of them in 100%, there allways will be some ''new amp'', never ending story.
Congratulations Borys! BG(X) with DC input and cascoded VAS. What's your listening impression?
Old 23rd July 2014, 06:38 AM   #3592
borys is offline borys  Ireland
borys's Avatar
thanks egra
The amp will be completed this week so maybe at the weekend I will have some time to verify if it was worth of doing it. Amp names BG9
Old 26th July 2014, 11:47 AM   #3593
hansenni is offline hansenni  Taiwan
hansenni's Avatar
Hello, everyone, for the first time sent a message, this is my DIY amplifier of 0dB
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 27th July 2014, 11:15 AM   #3594
thimios is offline thimios  Greece
Excellent work, congratulation.
According to which schematic is this?
Thimios.
Old 27th July 2014, 12:13 PM   #3595
SjoerdSmits is offline SjoerdSmits  Netherlands
SjoerdSmits's Avatar
Default Hiraga rebuild
Rebuild of my Hiraga 30 Watt Class A amp.
Old 27th July 2014, 12:19 PM   #3596
Default Inside
I soldered everything. No connectors left inside. This was a tip someone gave me so I did a complete rebuild.
Old 27th July 2014, 12:25 PM   #3597
Now waiting for original NEC 2SA634 transistors to arrive..... I hope they arrive quickly!
When this one is finished, I will also modify my B1 preamp the same way. No connectors of any kind, only soldered connections. Should be a big difference!
Old 27th July 2014, 04:59 PM   #3598
fotios is offline fotios  Greece
fotios's Avatar
Thimios.
Apparently is a true symmetrical design. There are four amplifiers total, bridged per two, to form the LEFT and RIGHT channel. And of course only balanced (XLR) inputs are offered of which the hot(+) is connected to the input of one amplifier and the cold(-) to the input of other. The speaker is connected across to the outputs of the 2 amplifiers, the pos. terminal at the output of "hot(+) amplifier" and the neg. terminal at the output of "cold(-) amplifier". There are some significant benefits offered by this topology.
Best Regards FOTIS ANAGNOSTOU
Old 27th July 2014, 05:56 PM   #3599
fotios's Avatar
Nice implementation hansenni . Let me guess:
+/-40Vdc supply per amplifier, so in bridge mode 160Vpp max output voltage swing.
That means a max power per channel:
80Vp / 1.4142 = 56.5Vrms
56.5 X 56.5 / 8 = 400Wrms @ 8 Ohms / 1KHz
56.5 X 56.5 / 4 = 798Wrms @ 4 Ohms / 1KHz
I suppose your toroids are rated at 800VA each one (or say at 600VA if you include a good VI limiter per channel).
BTW what means "of 0dB"?
Old 27th July 2014, 10:40 PM   #3600
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
It means this is fully differential (bridge) impedance buffer stage, having 0 dB voltage gain. It accepts balanced signal from any low Z high voltage preamplifier.
Post your Solid State pics here.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
