Post your Solid State pics here.
Old 21st February 2007, 09:01 AM   #21
fotios is offline fotios  Greece
fotios's Avatar
Originally posted by Bonsai
My Amp - I just fitted the front panel this weekend after it arrived from a company in Germany that cuts and engraves this stuff.
Hi Bonsai
It is easy for you to inform me, in who factory in Europe you ordered this beautiful front panel and the box of your amplifier, also how many cost these. I know only a factory in Germany, FISCHER ELECTRONICS known more for the excellent heatshinks that manufactures them I use exclusively in my constructions but it manufactures also boxes at order. Is this? I quote a photo of my trial power amplifier in order to you understand the situation in that be located.
Thanks in advance
Fotios Anagnostou
Best Regards FOTIS ANAGNOSTOU
Old 22nd February 2007, 03:06 AM   #22
Bonsai is offline Bonsai  Europe
Werner/Fotios,
Case is indeed from Fischer and front panel is from Schaefer.
Wow, very impressive looking amp Fotios - is it your own circuit design?
Moving forward, I will not use the Fischer case because it is expensive and the finish is not good. For example, very thin front plate, thin aluminium that cannot take any weight, only 4 screws on top and bottom plate. no ventilaation holes on the bottom - they wanted to charge me additional $45 and minimum order quantity of 3 cases to add this. I had to add a steel 'bridge' (that's the zinc plated metal you can see in the amp to take the transformer and my own feet - by the time I was finished, this thing cost me more than double. I found this guy through the forum and we have exchanged some emails - prices are good and the quality looks excellent. He already supplies to professional companies.
http://www.atiresearch-anodized.com/
his name is Arthon and he is very responsive. His cases clearly have been designed with some input from amplifier designers. I will be ordering some soon.
For the front plate, I used Schaefer, but be careful because they are also quite expensive and the follow-up is not so good. A US company, Front Panel Express provides the same service
http://www.frontpanelexpress.com/download/download.php
If you are based in Europe, then Schaeffer is a good bet - but I am in Tokyo, so the US is easier to deal with. There are some more photos of this amp in a proto form on the forum - look under 'Ovation Amp'
Old 22nd February 2007, 10:23 PM   #23
fotios's Avatar
Werner/Fotios,
Dear friend Bonsai
Thanks for your interest. The information and the links that you give it is very helpful, specifically that of ATI Research left me astonished, and i will contact with she in order to learn prices as i found ready boxes so for my amplifier as for the preamplifier - with discrete devices in modules - that I prepare. I am afraid however that i will be late somehow because I have spent all of my money in the research. Looking to the circuit of the power amplifier, yes it is my own design if we can consider him such, because simply it is a compilation from already known distributed topologies that i have selected deliberately in order to achieve a balance between cost and quality in combination with flexibility for the possibility of construction different in power output amplifiers, and her cost is roughly 350 as you see him without box totally realized with BJTs (small signal stages by use of MPSA06 - MPSA56, VAS and drivers by use of MJE15030 - MJE15031, and with 4 X MJL21193 + 4 X MJL21194 output devices per channel) with a power supply of +/-60Vdc at 500VA, individual for each channel ( thus the output power lies in 2 X 170Wrms/8 2 250Wrms/4 from 20 to 20000 Hz +/-1dB ) a damping factor of 400, a rise time of 1,9s, an input impedance of 50, with ultra low TIM and THD+Noise (i have not an analyzer to measure these but i observe these with my digital scope). It includes a smart analog computer for full protection of speakers but also the output stage from all kinds of short circuits, and an inrush current suppressor circuit. The only that is absent is a beautiful box in order to enclose this compact construction I have spend a lot of time to minimize her size and be tried for 1,5 year without problems. Also she is flexible as with the same circuit and with few additions it can reach a power output of 2 X 350 Wrms/8, he is also tried and this. Very soon I will make a complete presentation of this construction, step by step, in my web page; you will be informed for this. I quote below a photo indicating a channel from the trial module of a monster at 350Wrms/8 (with a supply of +/-86Vdc).
Best regards
Fotios Anagnostou
Old 22nd February 2007, 10:49 PM   #24
fotios's Avatar
For your politeness Bonsai
Below i quote a photo of the basic module with discrete devices that replace a usual operational amplifier such as NE5534 for the construction of a preamplifier or an electronic crossover etc. It operates with a supply of +/-28Vdc!! So to masked the fundamental or dynamic Johnson noise by more of +6dB and to can drive any low input impedance power amplifier, with enough meters of signal cable without the need of balancing the signal to force it. Contact with me via e-mail if you want to post you the schema to taste it. It is very easy to construct him. Sorry for the spell errors but i am hasty.
Again regards
Fotios Anagnostou
Old 28th February 2007, 12:14 AM   #25
HipoFutura is offline HipoFutura  United States
HipoFutura's Avatar
Anthony Holton's AV400. Includes a Velleman DC speaker protect board and a slow start circuit for the toroid.
Old 28th February 2007, 01:19 AM   #26
audio3000 is offline audio3000  Canada
Here's my entry:
Power output: 5W
Design: germanium front end, silicon driver, P-MOSFET output, N-MOSFET CS, OTL
Board:
left: power control and thump killer
right: Amplifier
Old 28th February 2007, 01:24 AM   #27
By the way, it's a monoblock design.
Here's the etched amp board. Laser printing on photopaper trick.
Old 3rd March 2007, 05:55 AM   #28
TomWaits is offline TomWaits  Canada
TomWaits's Avatar
Default QUASI from Down Under to East Coaster
From the thread Power amp under development I picked this design as my first DIY. I should have started with something smaller but my stomach said, "This is the place to start". I am very happy I did build this amp as it is a wonderful design. Extra special due to the fact that it was tweaked out right here on the DIY & sounds and performs like a great amplifier should.
It has since been re-wired with a Bias Adjustment but it is on loan at a friends and I have no new photos. And I fixed the burned-out LED with a new one.
Shawn.
Old 3rd March 2007, 07:27 AM   #29
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Shawn,
nice case job.
Not that i expected you to do a Virtual Mode WOODY=>Veritas
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 5th March 2007, 09:00 PM   #30
Tarasque is offline Tarasque  Netherlands
Tarasque's Avatar
Default My Holton AV400 amplifier
Pls see my version below
WWW.DelftAudio.com
Post your Solid State pics here.Hide this!Advertise here!
