Post your Solid State pics here.
Old 30th January 2008, 01:57 AM   #281
mr l is offline mr l  Australia
mr l's Avatar
hi all,
this is my effort, aussieamps av400 boards, homemade speaker protection, fischer heatsinks (10 kg each!) rifa 47000 uF caps. whole thing weighs 45 kg it's about to be upgraded with av800 boards that i've had for some time.
Old 30th January 2008, 01:58 AM   #282
mr l's Avatar
internal view
Old 2nd February 2008, 07:20 AM   #283
Mooly's Avatar
Default My latest amplifier.
Hi, Some piccys of my latest amp.
Old 2nd February 2008, 07:21 AM   #284
Mooly's Avatar
The rear panel, just below mains lead is a TOSLINK connector, used to send signal to a remote mains switching unit to power up source components.
Old 2nd February 2008, 07:24 AM   #285
Mooly's Avatar
Internal view, the circuit design is one of my own. Anyone recognize the metalwork of the power amp modules ?
Old 2nd February 2008, 07:26 AM   #286
Mooly's Avatar
Each amp module has D.C. protection P.C.B. mounted on right side with local filtering on left P.C.B.
Old 2nd February 2008, 07:29 AM   #287
Mooly's Avatar
The PreAmp. All input switching done at sockets with MOSFET,s in series shunt arrangement. Full remote control included Volume and input selection. All PC.B.,s hand drawn (took hours) just getting to grips with a C.A.D. Package so feel another project coming on
Old 2nd February 2008, 07:30 AM   #288
Mooly's Avatar
The power amp, not shown is 0.22 ohm series output resistor.
Old 2nd February 2008, 07:36 AM   #289
Mooly's Avatar
A poor pic part of preamp, the board at the bottom is a "hardware solution" to what should be done in software. The remote decoder is under the white plastic cover and I had to buy this in. Fully learning it will accept any "common" r/c commands, my pcb decodes the outputs and translates levels to operate fet switches.
Old 2nd February 2008, 07:39 AM   #290
Mooly's Avatar
All ready to go, an audience with Beethoven and the Takacs Quartet await.
Post your Solid State pics here.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
