Post your Solid State pics here.
Old 28th June 2012, 10:48 AM   #2541
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
I am currently building Miha Rauta's FC-100 amplifier.
Both channels work as designed, and I fastened them on the bottom plate of the ALU case.
Since I need some space for additional components (source selector, attenuation,...):
Shall I install the transformers one behind the other (as shown on the picture above), build some metall cage around them
and install the additional PCBs on the "first floor", or shall I stack the big black transformers one above the other?
Is there any recommendation what to do and what to do not?
Best regards - Rudi_Ratlos
Old 28th June 2012, 10:56 AM   #2542
east electronics is offline east electronics  Greece
east electronics's Avatar
SPEECHLESS......
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 28th June 2012, 11:19 AM   #2543
kees52 is offline kees52  Netherlands
Originally Posted by sakis View Post
SPEECHLESS......
yess agree
I have to build soon a case for the hybrid amp, after the pcb,s are ready afcourse, a type where the tubes can be seen on the above the front and or behind glass or plastic window, like this
The NEW Moscode 402Au Tube Hybrid Amplifier
Link as example for window, the other has the tubes up with cooling profile mosfets behind it.
Old 28th June 2012, 11:28 AM   #2544
chlorofille is offline chlorofille  Malaysia
chlorofille's Avatar
A masterpiece Rudi, looking forward to your listening impressions...
Old 28th June 2012, 11:35 AM   #2545
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by kees52 View Post
I have to build soon a case for the hybrid amp.......
is that a 6C19n ?
could I see a schematic of the tube section ?
or anything you know about this tube
PM if you like/prefer
Old 28th June 2012, 11:49 AM   #2546
Telstar is offline Telstar  Italy
How powerful are they? I find the talema/nuvotec potted transformers to be very quiet and decently shielded.
I would mount one above the other. Not sure of the little one.
Perpendicular respect the signal pcb is already the correct way
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 28th June 2012, 12:02 PM   #2547
Telstar,
the Talema transformers are 2 x 25 VAC / 225W each.
The small transformer is 4 x 34 VAC / 50W and supplies the frontend-shunts with power.
Old 28th June 2012, 12:26 PM   #2548
Originally Posted by tinitus View Post
is that a 6C19n ?
here the sound, as a idea, youtube is not so well sounding, also because I did only use a mid speaker with own little closed box and tweeter, but soundstage is big, it was a test to listen to platefollowers only. and yes, it sounds much relaxed, and special it give better bas.
real diy testing, real fun. - YouTube
Old 28th June 2012, 12:43 PM   #2549
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
what and what not?
Whichever is easier ?
Personally, i find fully resin encapsulated tranformers less practical than regular toroidals, due to the wires sticking out from the bottom.
Plenty commercial examples of stacked transformers, with/without a metal pan cover (e.g. Threshold monaurals)
If capacitor can height isn't the issue, a double-decker is easier, having an alloy metal plate folded to size is also cheaper than buying a (tall) transformer cover.
(there was a time when me used cheapo aluminum camping cooking pots as transformer covers, only takes a can of black spray paint)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 29th June 2012, 05:40 PM   #2550
Professor is offline Professor  Russian Federation
Professor's Avatar
My JLH =) More pics mymegahobby Jimdo-Page!
http://mymegahobby.jimdo.com/
Post your Solid State pics here.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
