Post your Solid State pics here.
Old 7th November 2011, 10:08 AM   #2051
Shah,
what is the purpose of this?
1,907px 1,066px
Apex,
what is the purpose of re-posting the same pics?
regards Andrew T.
Old 8th November 2011, 12:07 PM   #2052
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Your post 2045 Sakis... is this a Class D amplifier?
A class D amplifier based in 555 Ic?
Nice.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 8th November 2011, 07:46 PM   #2053
ROCKMANDRAKE is offline ROCKMANDRAKE  France
Default Pfm The L@st V2
now, fitted with ultimate output transformers 'n' K75-10 capacitors...
Old 9th November 2011, 12:57 AM   #2054
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Default Jfet BOZ so far
Jfet Boz so far... just need to add alps pot, filter caps, 2x nine volt batteries, and rca jacks, case & knob too.
Old 9th November 2011, 06:54 AM   #2055
igor0203 is offline igor0203  Slovenia
Nice. How does those Valab caps sound?
Old 9th November 2011, 01:24 PM   #2056
I haven't finished the build yet. They're PIO caps, they should sound great.
I'll keep you posted when I've completed the build.
Old 10th November 2011, 07:34 PM   #2057
osscar is offline osscar  Latvia
osscar's Avatar
This is my version of the OBH 8SE Phono amp:
electrolytic capacitors in signal path replaced with film-type capacitors;
Power supply based on LM 317 but with batteries sounds little better for me.
Overall I am satisfied with the sound - i like it - it sounds more detailed then my Pacific style RIAA because the THD is lower, i think so.
inside:
Back panel (i still use old TT with DIN connector-do not want to damage the original TT)
front (with Leach amp)
My DIY : http://www.tutribi.net
Old 12th November 2011, 01:48 PM   #2058
lanchile is offline lanchile  United States
lanchile's Avatar
Thumbs up My new integrated amp!
Here some pictures of my new integrated amp. The design is from HDamplifier.com. This is my second time that I order from them. The first time I build the T300 and now is the M400. the offset I get is 1.7 mv Left channel and 1.8 mv Right channel. The sound is very nice,I am using the chassis as a heat sink, it gets warm and if I push it..it get a little hot. I will put external heat sinks in the future. I am happy with the results!!! Excellent kits.
By the way, the whole chassis is aluminum and the side is really thick, but as I said before, I will put external heat sink in the near future.
Old 12th November 2011, 04:18 PM   #2059
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Post your Solid State pics here.
How long to land a scottish complaint???
Max.
Old 12th November 2011, 05:58 PM   #2060
east electronics is offline east electronics  Greece
east electronics's Avatar
replace the wiring of the pot .... to close to the trafo it will pick up something there i think .... go for shielded cables .....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Post your Solid State pics here.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
