Post your Solid State pics here. Post your Solid State pics here. - Page 203 - diyAudio
Old 17th October 2011, 12:34 PM   #2021
post reported.
Alex, the schematic you have posted cannot possibly be built as you have shown.
There is some serious error in the schematic, that you appear to be unaware of.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th October 2011, 12:39 PM   #2022
Alexontherocks is offline Alexontherocks  Italy
OK so it should not work and it is unsafe.
Interestingly enough I was provided with the bare PCB of this finished product
Link to softstart board removed by moderation
Built 4, tested them with all sorts of toroid combinations and have worked fine ever since.
Old 17th October 2011, 12:58 PM   #2023
and by the way....regarding the problems you pointed out:
Sure the pcb is not isolated but it is possibile to obtain a DC tension without a transformer as long as the current absorbed is small. The pcb uses reactive capacitance to create the DC current.
the IDEC RU2S-A220 suggested for the build and visibile in the photographs is a relay driven with 220v.
The IDEC Ru2s-D24 is the second relay suggested and both offer interesting features such as a built in LED, a test function and are best mounted using a specific socket which helps in case of failures.
In regards to the NTC thermistors. I honestly don't seen a problem. IF two NTC 10D-20 are adequate for inrush currents to the toroid then what might happen with 2 groups in parallel would be for either one or the other to drop resistance and channel the surge current (thus leaving one group non functional given the resistance differential). If continuity across one branch is lost then the second would work as a failsafe.
If you see anything wrong with all of this please tell me.
Old 17th October 2011, 01:03 PM   #2024
Pano is offline Pano  United States
Pano's Avatar
Alex, is this circuit followed or proceeded by a transformer? It's not shown in the schematic.
Old 17th October 2011, 01:17 PM   #2025
No transformer.
Old 17th October 2011, 01:23 PM   #2026
On Hiatus
SY's Avatar
Originally Posted by Alexontherocks View Post
No transformer.
That's VERY unsafe. So unsafe that we have only ONE rule regarding technical censorship on this forum: NO direct mains-powered circuits.
Use an isolation transformer and make sure that your chassis is tightly connected to earth ground. Otherwise, you're risking your own life and that of innocent family, friends, and kids who could get electrocuted from a simple fault that (in a safe build) would blow fuses.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th October 2011, 01:24 PM   #2027
However setting AndrewT's bashing aside....the circuit does contain a mistake. Infact 2x 0,33f MKP 275 entrance capacitors are missing... I will post the correct schematic in a moment..
Old 17th October 2011, 01:26 PM   #2028
I understand....then please delete my posts
Old 17th October 2011, 01:49 PM   #2029
dadod is online now dadod  Croatia
dadod's Avatar
No transformer.
Of cource there is a transformer connected to J4.
Old 17th October 2011, 03:41 PM   #2030
FastEddy is offline FastEddy  United States
FastEddy's Avatar
Yes! ... So unsafe that insurance companies have been able to block payments for fire liability, in many states ... If you burn your own house down, insurance companies may not be obligated to pay. If you burn your apartment building down, you could go to jail and be liable for all of the damage and injury.
Post your Solid State pics here.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
