Post your Solid State pics here. Post your Solid State pics here. - Page 160 - diyAudio
Old 14th October 2010, 07:58 PM   #1591
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
There must be something wrong - each time I turn it on our neighbourhood electricity trips out.
If you don't want to listen to it, it has other uses such as pump motor speed control, transportable arc welder, etc.
Old 14th October 2010, 08:52 PM   #1592
Federmann is offline Federmann  Czech Republic
Federmann's Avatar
Send a message via ICQ to Federmann Post your Solid State pics here.
Intelligent power management module.
Old 15th October 2010, 12:10 PM   #1593
Napster050 is offline Napster050  Slovakia
My Symasym 5.3, engraved front panel
Old 16th October 2010, 02:07 PM   #1594
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Wow that really looks good.
Where did you get your engraving done?
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 18th October 2010, 11:34 PM   #1595
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Napster, open it up, we want the porn ones pictures
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 18th October 2010, 11:39 PM   #1596
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Porn, nude everything
Regards zeoN_Rider
Old 18th October 2010, 11:39 PM   #1597
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Class D IRS2092 in progress.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 19th October 2010, 04:33 PM   #1598
Inside is "Cable Jungle"... These are old photos... output terminals are replaced with better
Old 19th October 2010, 08:27 PM   #1599
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Nico Ras View Post
How about two monoblocs running 6A bias current and pushing 5.6 kW continuous into 4 Ohms resistive. Makes your experience at a Pink Floyd concert pretty realistic.
Tu Ras , i likey ...................
Old 20th October 2010, 06:42 PM   #1600
boyofwax is offline boyofwax  Netherlands
boyofwax's Avatar
Default Recently finished voltage amplifier.
I've finished an opamp to drive my SE class A mosfet amp. I just wanted to share a beautifull pic The diagram is only in my head. The TL082 and elco's perform just aswell as a BB opa2228 and MKT/MKP caps. With the pot's I an set the desired gain. It is made a non inverting amp.
Together with the mosfet amp I have put it in an equalizer.
Post your Solid State pics here.Hide this!Advertise here!
Copyright 1999-2017 diyAudio
