Krell KAV 250a deader than a dodo
Old 18th November 2007, 06:24 PM   #61
digitallake is offline digitallake  United Kingdom
Andrew LOL - despite appearances I'm not that stupid!
I'm just a wee boy you know
Old 22nd November 2007, 01:17 PM   #62
K-amps is offline K-amps  United States
K-amps's Avatar
Originally posted by digitallake
Hi K, Pinkmouse
OK - so the transformer is ok!
I tested it out of the chassis with a lamp lead and no glow - the secondaries read 65V each.
I tested the rectifiers and caps both are ok, so I put in back in the chassis, connected the rectifiers back up and tested it again with the lamp lead.
On first switch on the lamp glowed full brightness, I immediately switched it off. I double checked everything, seemed ok, so I switched it on again. This time the lamp dimmed over about 2-3 seconds then went off. I tested the DC rails at this point and they were reading +/- 92V so I guess it's ok, then???
Confused as to why the lamp glowed in the first place, I can't get it to do that again, but the filter caps were completely discharged first time round.
Confused. But happy
Question is why it happened... Perhaps the AC mains fuse was fast acting? The caps completely discharged? The current inrush limiter not as cold resistive as should have been? Some PSU connection shorting to the chassis ground?
Jim: The trannies are being packed today. Sorry for the delay.
Old 31st August 2009, 04:54 AM   #63
im1663 is offline im1663  Hong Kong
Last week, My output transistor of 250a were all shorted, I replace it with MJ15024/25 and it work properly, the off-set output voltage is below 100mv
Old 31st August 2009, 11:44 AM   #64
have you compared the difference in current through each output device?
Have you monitored the way output offset now varies with temperature and during the warm up phase?
Does the 250a have an adjustment to reduce output offset?
regards Andrew T.
Old 2nd September 2009, 03:33 PM   #65
There are two port for adjustment but I didn't adjust it.
The offset voltage drop to 40mv for 10 hour continous working
I haven't compare the current thr each output device, it is a good question.
By listening test, I can't notice the difference.
Old 15th January 2010, 01:30 AM   #66
Yes, there are two trimmers in the amp, the one near MPQ6600A1 (Quad complementary pair) is for adjust the offset.
Another one near the bias transistor 15031 mount on the heat sink is for adjust bias.
Old 2nd March 2010, 06:13 AM   #67
carz is offline carz
There are 2 jumpers on the power supply board, J2 (Power- Mains) and J3 (ON/OFF - Manual). Do you guys know what these are for ?
Also what is voltage value for TP1 and TP1 and in relation to what ?
Old 20th March 2010, 08:37 PM   #68
anatech is offline anatech  Canada
anatech's Avatar
Hi carz, all,
Without the service information, I would recommend that you should leave their products alone. I would also support the same action in the retail stores. Leave Krell products alone to sit on the shelves (don't buy them).
If you can find an authorized service shop that is reasonable to deal with, allow them to do just that. I feel the possibility for abuse from Krell and their network is high, so maybe that one good shop can help ...
As for poking around taking measurements, don't. One error and you could be in for an expensive repair job. Even the shipping on these is terribly expensive.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 30th January 2011, 09:55 AM   #69
peter460 is offline peter460  South Africa
Any one know what the bias voltages on the emitter resistors should be on KAV 250 ? One channel of mine is 7 mv and the other 15 mv . Rail current on both 220mA
PEter
Old 12th July 2017, 08:03 PM   #70
dvavc is offline dvavc  United States
[QUOTE=K-amps;1135997]Jim:
... Don't use the 15025/5's either, they don't sound as nice as the newer devices...
K-amps, so which one you recomend should (and may) be used on original Krell KAV 250A board for better sound? 21195/6?
Tks.
Krell KAV 250a deader than a dodoHide this!Advertise here!
Bogen model HTA-250A tade Solid State 12 13th May 2012 12:32 PM
FS- B&O ICE Modules (250ASP & 250A) Guiness Swap Meet 8 3rd July 2008 09:35 PM
ICEPower modules for sale (250A) Alfetta87 Swap Meet 8 22nd June 2008 05:46 PM
