Old 11th February 2007, 07:56 PM   #1
Default Sub plate amp hum/crackle
Sorry for posting this again months later. I posted about this on the subs forum but thought I might have better luck here.
I have the MCM $50 plate amp, it introduces hum into my system whether I use the preamp inputs or speaker-level inputs. System is otherwise dead quiet. Groud loop isolator fixed the problem and made the system sound like crap (my wife noticed it immediately, I'm not hallucinating). Back to square one. I tried all combos with other plugs and outlets to no avail. It does go away if I unplug connections to the amp or if I unplug both amp and plate amp, then plug the amp back in.
anyone have any ideas?
GhettoSQ
Somewhere between Craft and Kraft
Old 15th February 2007, 01:59 PM   #2
BUMP
I realize my question above is a bit silly, since the GLI fixed the problem there must be a ground loop. I just hope there's another way to solve it since the GLI hurt the sound quality.
Also, today it's just kind of a hiss -- barely noticeable but more than it was without the sub.
GhettoSQ
Old 15th February 2007, 02:30 PM   #3
Did it Himself
richie00boy's Avatar
Are all parts of the system plugged into the same mains socket?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th February 2007, 03:35 PM   #4
Yeah, they are all on a power strip into one socket. I tried just the two amps (main and sub) on the two outlets of the socket too. I changed to a slighty heavier-duty power strip too, to no avail.
GhettoSQ
hk 770 snap crackle pop new_wes Solid State 1 23rd May 2010 07:13 AM
HOT ROD DELUXE: CRACKLE...POP...what to do? juicy1484 Tubes / Valves 17 29th April 2010 02:08 PM
Crackle !! can't solve ?? titanchen68 Class D 29 7th May 2006 03:20 AM
Amp Crackle DoubleWammy Instruments and Amps 4 23rd April 2005 02:51 AM
Pop/crackle in one channel Saurav Tubes / Valves 16 28th November 2004 11:21 PM
Page generated in 0.09805 seconds (58.99% PHP - 41.01% MySQL) with 10 queries
