Need Cambridge A500 help Need Cambridge A500 help - diyAudio
Old 11th February 2007, 04:50 PM   #1
mdelrossi is offline mdelrossi  United States
Default Need Cambridge A500 help
I just picked up a A500 the fuses on the main board keep blowing.
I was wondering if anyone had any ideas ?
Should I replace the SAP15's, and see what happens?
I saw in another thread , OzOnE_2k3 had some experiences repairing these , If you are out there could you chime in?
thanks in advance. I will contact Cambridge Audio and see if I could get a Schematic.
mdr
Old 11th February 2007, 05:34 PM   #2
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
1.Check your rectifiers and capacitors in the power supply section.
2. Check for collector to emitter shorts on the final outputs.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 11th February 2007, 07:28 PM   #3
do I have to de-solder them or can i check them on the board?
thanks
I'm a neewb for now
mdr
Old 11th February 2007, 08:58 PM   #4
jaycee is offline jaycee  United Kingdom
You should desolder the transistors to check them.
You may also want to check the MJE340/350 transistors as these could've gotten fried as well.
Old 11th February 2007, 09:01 PM   #5
Do you know how to check a diode or rectifier with a dmm. Do you have a dmm. To answer your question ideally yes, lift one side of the diode. If you have a bridged rectifier it would be best to removed from board.
Old 11th February 2007, 10:27 PM   #6
I've got a DMM, but looking to get one that is also an LCR meter. Any thoughts on an inexpensive one?
Thanks for your advice I'll set apart some time tomorrow to test them.
mdr
Old 11th February 2007, 10:48 PM   #7
I picked up an el'cheapo lcr off of ebay no- name brand for $29 probably only good for ballpark measurements. Fluke has always be a good bet!
Old 11th February 2007, 11:05 PM   #8
MikeW is offline MikeW  United States
MikeW's Avatar
Default Take a look
Sometimes there is a burnt mark or other evidence of what blew up. I have blown the top right off some transistors.
MikeW
Old 2nd August 2007, 06:02 PM   #9
Hi all.
I got the replacement SAP15 N&P.
Soldered them in and the amp doesn't blow, But the channel that I replaced the SAP's has a lot of static like you are trying to connect a speaker with the amp on. I have the schematic that Cambridge Audio was kind enough to send me.
here
Any help would be appreciated.
thanks
mdr
Old 2nd August 2007, 10:30 PM   #10
mdelrossi
First lets see if your power supply is working. I need to know what the voltages are on pins 2 & 3 of U203 and U204.
Need Cambridge A500 helpHide this!Advertise here!
Cambridge audio A500 amp with broken right channel sammydee Solid State 26 19th May 2009 08:12 PM
Cambridge Audio A500 is dying. APE-MAN Chip Amps 2 19th October 2008 11:29 PM
cambridge a500 problems reddish75 Solid State 17 23rd February 2008 02:01 AM
cambridge audio a500 amp problem tim0850 Solid State 3 1st March 2005 08:13 PM
Copyright ©1999-2017 diyAudio
