I tried to use search to get an answer to this but with no success.
Could anyone explain to me in a basic way how manufacturers take a sub amp and modify it to get a lower roll-off from their sub in its cabinet? For instance, I think the midbass sound my JBL 2020h creates is second to none, but it dies at 70hz. What if I could tweak an amp to get it down to 50hz? I don't know anything about amps; I'm just trying to get a basic understanding of how amps are modified to produce more power at certain frequencies. |
#2 |
Maybe this could be your solution.
http://sound.westhost.com/project71.htm or this http://sound.westhost.com/project48.htm
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
you have preamp circuitry with rolloff at 70 hz. you need to find any coupling capacitors in your preamp section and either increase the capacitance, or if they're not blocking DC, remove them and replace them with wire.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#4 |
"you have preamp circuitry with rolloff at 70 hz. "
He has a JBL 2020H, can you say: no bass, zip, nada? This driver has Fs=60hz, low, low, low Qts=0.23, that spells no bass. If you use the recommended venter box tuned to 40hz, it will be 92dB at 40hz, and over 105dB at 2Khz. It has a coil overhang of 0.05", so don't bother trying to boost the bass. This driver is intended for maximum midbass output on a large horn.
Candidates for the Darwin Award should not read this author. |
#5 | |
Did it Himself
There is no need to change any caps. The issue is the driver.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
Well that particular driver is a side issue anyway; I was looking at the current 'low frequency' models by JBL as well. But the links are great. At least now I can get a handle on how its done.
| subwoofer box question | mike49504 | Car Audio | 6 | 1st February 2009 04:32 AM |
| First DIY Subwoofer, Amp question | Lokalazeros | Subwoofers | 36 | 24th January 2008 03:10 PM |
| subwoofer question | mike49504 | Car Audio | 1 | 7th February 2007 01:37 PM |
| Another which subwoofer question... | RockysDad | Subwoofers | 17 | 15th October 2006 01:46 PM |
| Subwoofer question | MisterB | Subwoofers | 23 | 23rd March 2002 04:32 PM |
| Page generated in 0.09422 seconds (65.13% PHP - 34.87% MySQL) with 10 queries |
