Hi. I purchased a NAD 3020 a month ago. The input jacks worked when I got it, but somehow damaged when I tried to put male cable-It was very hard to connect so I probably put it too strongly.
Right now, only 1 source(tape) is working in both channels. Only 1 channel is working in Aux and Tuner input. Both of them are damaged in right channel input, which are located in deeper position.(You know what I mean if you have had this amp) How could I fix this myself? Thanks in advance. |
#2 |
frugal-phile(tm)
The way the RCAs are board mounted on the 3020 often leads to failure. You can try resoldering -- if that doesn't work, the actual jacks are probably broken -- you'd need to replace them (i'd drill some holes in the back, mount chassis mount RCAs and run a short bit of wire from the board to the new jacks.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I had the solder joint on one of my phonos crack, re-soldering fixed it. A swap-in replacement phono looks hard, I've searched every connector-maker for that footprint; I think I'll be following planet10's suggestion.
It's also worth cleaning out the switches with a contact cleaner aerosol, they can give channel loss. |
#4 |
Thanks for your replies. I don't have any experience or knowledge about soldering. But I think I can get some help from my co-worker, though I have to do the main job. Could you give a little more detail exactly which part to solder? Starting from which part to open first? Thanks a bunch.
John |
#5 | |
Adding jacks to the back plate is a good idea, but you'd also have to make sure they clear the regulator board. In general, I find working on the 3020 a pain, with so many little odd wires all over the place, and awkward construction of the case... but I'm getting used to it, and slowly removing some of the unnecessary wires... :-)
Shawn NAD 3125 & 3020 amps, 4125 tuner / Rotel RCD-965BX CD / B&O 2400 / Nakamichi BX-125 / PSB 70R speakers / BrianGT chipamp in progress... |
| hum problem in NAD 3020 (help wanted) | garyk | Solid State | 7 | 12th August 2008 04:50 PM |
| NAD 3020 problem | vubkevin | Solid State | 16 | 11th December 2007 01:08 PM |
| NAD 3020 Channel Problem | GhettoSQ | Solid State | 9 | 19th December 2006 10:53 AM |
| NAD 3020 Problem | diddytong | Solid State | 7 | 22nd July 2005 04:15 PM |
| guitar amp input jack help | BelieveInKarma | Tubes / Valves | 16 | 30th December 2003 04:44 PM |
| Page generated in 0.09156 seconds (68.75% PHP - 31.25% MySQL) with 10 queries |
