As I turn the volume control on this integrated amp, I get a slight buzz sound, but only on portions of the travel. For example, dead quiet between 1-15, buzzy between 15-20, dead quiet again after 20. Could this be more than just the volume pot?
#2 | |
Hi Piercarlo |
#3 | |
Hi DreadPirate,
Odd problem. Order a control from Denon. Hi Piercarlo, I did warranty on these. They were not built like Threshold or other high end brands, but then again they were put together better than many others. You can't knock them for that! They were good value for the money. Quote:
Denon was manufactured to a level a bit higher than the price tag. You can not fault them for not being as well built as top end products. There were very few troubles with Denon (over here at least). -Chris |
#4 | |||
Hi Piercarlo |
#5 | ||
Hi Piercarlo,
Well, I am just interested if you actually did troubleshoot the actual cause in any of the two you saw. What I do have a problem with are the following comments you made .... Quote:
If the source goes open, you can expect to pick up noise in any design. Often companies run signals through flat cables alternating ground and signal. I don't like the practice, but it does seem to work inside a shielded case. Even very high end manufacturers may do this from time to time. If every signal was carried inside a shielded conductor, you could expect some capacitance that then has to be driven. I guess these are real tradeoffs. -Chris |
#6 |
This actually could be a common, yet undetected problem. I only pick it up on headphones while doing a very critical evaluation. I like the sound of this unit, will probably spring for an ALPS pot, I'll report back if that did the trick, can't say when I'll get around to it, unit is fully functional otherwise.
The volume control was quite noisy before I cleaned it. |
#7 | |
Hi Dread,
-Chris |
#8 |
Hi Piercarlo,
Well, I am just interested if you actually did troubleshoot the actual cause in any of the two you saw. What I do have a problem with are the following comments you made "then the cause is a latent unstability of the preamplifier that follow volume pot". and "A problem not new with Denon what not ever care properly ground routings" I would have seen this for sure! Well. I've buy used, some years ago, an old PM 502 (or so) which exhibits the same defect (plus others) described by DreadPirate about its 520. Instabilities were due to a subsequent volume circuits which were designed in order to behave as a "tube-like" circuits (especially from the NFB viewpoint), with tone network embedded in the NFB network of main preamplifier stage instead of being implemented in an active dedicated circuit as usual. Internal cabling was just of unscreened kind but with a little "trick" that masked the problem: input sockets have an internal spring that short input to ground when no cable is inserted: i don't perceived the problem til a day I've left inserted a CDP (a Philips CD104 with an unusual grounding scheme that, when off, is floating and heavily humming). Chasing for the cause of huge humming I've neared my hands to the bunch of cables (that believe shielded although not thick) and hum raise heavily.... and so the truth come out: no internal screen of any kind, neither for the phono MM stage, was used. "I don't like the practice, but it does seem to work inside a shielded case. Even very high end manufacturers may do this from time to time. If every signal was carried inside a shielded conductor, you could expect some capacitance that then has to be driven. I guess these are real tradeoffs". May be... However this practice I've meet for some three-four times in the years and in every case hum was slightly heavier than usual. Another problem I've noticed in this case was a markedly, audible higher diaphony than the usual. In uone situation (Leak 1800) this practice appear to have somewhat compromised high frequency stability (not at the top however...) because the amplifiers sounded sensibly more or less harsh as I moved the internal cables (wrapped toghether with plastic ribbons). Hi Piercarlo |
#9 | ||||
Hi Piercarlo,
-Chris |
| MENG Series "EL34B" Integrated Amplifier | stevenscoffee | Tubes / Valves | 2 | 8th July 2008 07:10 AM |
| "Integrated" or "stand alone" | RenegadeAmps | Tubes / Valves | 13 | 11th October 2006 08:05 PM |
| The first tube "integrated circuit" (1926) | jackinnj | Tubes / Valves | 3 | 19th March 2005 02:34 PM |
| Need help with IC Based Amplifier "pop" problem (Integrated Component) | Monolith | Solid State | 7 | 13th March 2003 03:01 PM |
| Page generated in 0.16976 seconds (69.64% PHP - 30.36% MySQL) with 10 queries |
