Old 8th February 2007, 11:40 AM   #11
Elvee is offline Elvee  Belgium
Default Re: Re: Re: Re: Output clamping diodes:When do we need them???
Originally posted by Piercarlo
Is simple: imagine a power amp throttling about to half maximum output voltage and playng consistent bass content which usually require current beefing from output devices. In case of sudden disconnection of output cables, especially if long and connected to complex crossover, a voltage spike that may occur may be insufficient to activate the usual clamping C-E diodes ma enough to reverse breakdown the B-E junction of output devices and damage it (usually shorting it).
The spike occurs at the output cables, not the amplifier output. The amplifier is completely safe in this situation.
LV
Old 8th February 2007, 01:40 PM   #12
Default Re: Re: Re: Re: Re: Output clamping diodes:When do we need them???
LV
Sure of that? Why?
Piercarlo
Old 8th February 2007, 02:05 PM   #13
Default Re: Re: Re: Re: Re: Re: Output clamping diodes:When do we need them???
Sure of that? Why?
Piercarlo
Because the voltage spike occurs on the inductance, when it is disconnected , and by definition, at that time, it is.... not anymore connected to the amplifier, which is therefore isolated from any consequences.
And if the spike is high enough to generate a spark that closes the circuit again, the current finds the way it followed before the break, and the overvoltage is quenched automatically.
LV
Old 8th February 2007, 06:58 PM   #14
Default Re: Re: Re: Re: Re: Re: Re: Output clamping diodes:When do we need them???
Because the voltage spike occurs on the inductance (...) and the overvoltage is quenched automatically.
LV
You are right but you are also too trustful in being on the bliss side of Murphy's law....
Hi
Piercarlo
Disk Clamping - Which is best ?? poynton Digital Source 32 1st January 2010 04:57 PM
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
lossless clamping with current sense, how? zilog Power Supplies 5 25th July 2008 11:59 AM
Parts FS : Output Devices/Diodes/Regulators/Opamps and Misc. Items dtm1962 Swap Meet 5 8th September 2007 01:25 AM
Diodes on power supply output for voltage drop? bst Tubes / Valves 7 12th July 2007 03:54 PM
Page generated in 0.10854 seconds (59.00% PHP - 41.00% MySQL) with 10 queries
