Why are Emitter-resistors needed?
Old 4th February 2007, 10:53 AM   #1
Fritzell is offline Fritzell  Sweden
Default Why are Emitter-resistors needed?
In BJT amps there's no question about it, but in MOSFETS? Are source-resistors really needed to prevent Iq from excursion? Even in parallell output, I believe in theory it shouldn't be needed. I've read about in the Wiki but I would like to see some non-theoretical evidence too it.
I'm gonna do some tests later this day about this, but I'd like to know if anyone has a comment about it
Old 4th February 2007, 11:14 AM   #2
Nigel Goodwin is offline Nigel Goodwin  England
I believe it depends on the particular devices?, FET's are supposed to have a negative temperature coefficient, so automatically prevent thermal runaway and have no problems in parallel. However, many high power audio devices don't have a negative temperature coefficient, so require resistors just like bipolar.
Nigel Goodwin
Old 4th February 2007, 11:42 AM   #3
AndrewT is online now AndrewT  Scotland
Lateral FETs have a -ve temp coef above about 500mA so are effectively self protecting when used in parallel.
Source resistors here help the circuit to stabilise the quiescent and dynamic currents.
Vertical FETS have a -ve temp coef above about 6A to 40A depending on model. At these kind of currents and at the voltages used in audio they are already destroyed before they get out of the +ve coefficient region.
Source resistors are mandatory for current sharing when driving the output.
At quiescent conditions, things are a bit different.
Very accurate matching can equalise individual Iq resulting in near identical junction and case temperatures when no output current is flowing.
regards Andrew T.
Old 4th February 2007, 11:59 AM   #4
hacknet is offline hacknet  Singapore
i read somewhere that the emmitor resistors are required to prevent the devices self distructing on turn on due to the suddent surge in current.
is this true?
Old 4th February 2007, 12:21 PM   #5
Thanks for Your replies. Ok so the tempratur-coef can vary from devices. How about an old faithful IRF540/9540? I think Iv'e got these on my shelf so I shall try with these later. First single output and see if Iq rise when they are hot.
I had a look at the datasheet for IRF540 and the curve Temperature vs. Id is of interest but it seems like the current has to go very high to take these effects that we're talking about.
Old 4th February 2007, 12:54 PM   #6
If in doubt, add the resistors, they won't do any harm, and may well make the amp more reliable.
Nigel Goodwin
Old 4th February 2007, 01:01 PM   #7
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Yes they have a neg TC but only at currents higher than normally used in audio bias, so the effect is pretty useless unless you use them in heavy biased class A.
Another reason for the Re is to smoothen the cross-over region to avoid hard xover distortion (it is local feedback), and in case of multiple parallel devices, to help equal load sharing.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 4th February 2007, 02:05 PM   #8
john_ellis is offline john_ellis  United Kingdom
Hi all
actually there are competing mechanisms in mosfets.
But, I think you mean positive temperature coefficient when you said negative.
A positive temperature coefficient makes the resistance increase with temperature, a negative tempco decreases it.
In a Mosfet, the Vt has a negative tempco, while the channel resistance has a positive tempco. This means that for each fet there will be a temperature neutral point, which as people have said already, only works at relatively high current.
Because most fets are biased to a relatively low current (well, maybe 100 mA or so) to avoid crossover, the Vt is still usually in the negative tempco region, so needs a bias stabiliser.
Parallelling MOSFETS without local source resistors can be dangerous - especially at high frequencies and currents, the impedances need to be matched to make sure that one device does not hog the amps and destroy itself.
cheers
John
Old 5th February 2007, 11:42 AM   #9
Aha I understand, thank you.
But Vbe multiplier won't be as critical? Iv'e seen many designs with just a potentiometer..
Old 5th February 2007, 11:59 AM   #10
Piercarlo is offline Piercarlo  Italy
Piercarlo's Avatar
Many designs are just good for french fries... Vbe multiplier is not well apted to mosfets biasing because mosfets havent not Vbe at all. But if nothing of better is available (as may be a dedicated biasing circuit as that provided by Linear Technology LT1166), a Vbe multiplier is surely more reliable of a raw potentiometer.
Hi
Piercarlo
Why are Emitter-resistors needed?Hide this!Advertise here!
MPC70 0.27 ohm 2W emitter resistors Luke Swap Meet 5 2nd June 2015 11:58 PM
7w dual emitter resistors? JJGross Parts 3 1st July 2008 05:37 AM
Dual emitter resistors - where from? Stuey Parts 14 10th March 2007 07:58 AM
Emitter Resistors hawkfeather Solid State 15 29th January 2006 06:28 AM
Emitter Resistors EchoWars Solid State 16 16th July 2005 11:47 PM
Copyright ©1999-2017 diyAudio
