Old 3rd February 2007, 05:53 PM   #1
Default Transformer from Sony A/V Receiver - what's up with these windings?
A friend gave me a transformer from a Sony A/V receiver. He didn't know the Sony model, I think it was 7 channels, or maybe 7.1, possibly 100 Watts per channel. I figure if Sony was claiming 7 channels of 100 Watts, it might be a good start for a 2 channel 100 Watt amplifier. Output devices are MP1620 / MN2488.
The secondary high current winding has 5 wires, with voltage as follows, measured with 120 VAC on primary, no load on secondary:
Orange - 44
Yellow - 27.4
Black - 0
Blue - 27.4
Red - 44
So, we have the makings of a +/- 62 VDC or +/- 38 VDC supply. According to my math, that would be about 240 Watts or 90 Watts into 8 ohms.
Anybody know how this thing was used? Guesses also welcomed.
Old 3rd February 2007, 09:58 PM   #2
XEAGLEKEEPER's Avatar
Sounds about right. If there is a part number you could call sonys techline and maybe find out the VA rating?
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 3rd February 2007, 10:20 PM   #3
zeonrider's Avatar
Default Hi !
Measured dimension of that transformator.
Maybe we can calculate VA rate(transform in mm ).
Regards zeoN_Rider
Old 3rd February 2007, 10:34 PM   #4
Have you tried googling that part number?
Old 3rd February 2007, 11:19 PM   #5
Actually, what I was wondering about was the voltages - one pair seems too low for a 100 Watt amplifier, the other pair seems way too high.
I was hoping maybe someone had seen one of these before and knew what Sony did with those taps.
Old 3rd February 2007, 11:26 PM   #6
Have a look at these amps
http://sound.westhost.com/project3a.htm 100watt 38vdc
http://sound.westhost.com/project101.htm 180-200 watt 66vdc
Old 5th February 2007, 04:59 AM   #7
Thanks for the amplifier recommendations XEagleKeeper, but allow me to drag this back on-topic:
Why are there two sets of taps on the secondary?
Old 5th February 2007, 10:21 PM   #8
Probably because the sony required two different supply voltages.Real hard to say without a schematic!Possibly lower voltage for the preamp,flatamps and higher voltage for the poweramps???
Old 6th February 2007, 04:33 AM   #9
Hmmm. +/- 38 VDC is a bit high for a preamp, and I have no idea what a flatamp is (neither does Google ). And this is the high current winding - there is a separate low current winding measuring 14-0-14 that is almost certainly for the low-level stuff.
Thanks.
Old 6th February 2007, 07:28 AM   #10
djk is offline djk
djk's Avatar
Voltages sound right for a 5-ch 100W class H amplifier.
Candidates for the Darwin Award should not read this author.
Big transformer (pulled from Sony receiver) maurycy Swap Meet 0 1st December 2008 01:29 PM
Transformer Windings impsick Chip Amps 6 2nd February 2007 11:00 AM
transformer primary windings Q AndrewT Power Supplies 6 28th October 2006 11:51 AM
Unused HV windings on power transformer Bill*B Tubes / Valves 2 5th March 2005 09:42 PM
Transformer windings identifications - how to get it? Alfetta87 Solid State 7 21st February 2005 04:01 PM
Page generated in 0.14528 seconds (57.78% PHP - 42.22% MySQL) with 11 queries
