Old 3rd February 2007, 01:20 AM   #1
jackinnj's Avatar
Default Taming of the slew rate measurement
Taken from Jim Williams application note #94 "Slew Rate Verification for Wideband Amplifiers" -- I liked the title as I was noodling around.
So the formula goes like this --
SR = 2 * pi * BW * SQRT (2*P*R)
for specifying the "full power" bandwidth, does one mean "that point" in the distortion vs frequency plot where distortion becomes significant, i.e. over 0.1% or 1.0% -- or does it mean that point where the output power is down a certain decibel value from 20kHz?
Old 3rd February 2007, 02:36 AM   #2
andy_c is offline andy_c  United States
Banned
Default Re: Taming of the slew rate measurement
This sounds like it's related to Mr. Shake-a-spear (or is it Shakespierre?) somehow .
But seriously, for a sine wave v(t)=Vmsin(omega*t), the maximum time derivative is omega*Vm (at the zero crossing). In your formula above, SQRT(2*P*R) is just the peak voltage Vm. So the full power bandwidth is the frequency at which the maximum time derivative of the the sine wave output voltage at full rated power is the same as the slew rate.
Old 4th February 2007, 03:39 AM   #3
thanh is online now thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
Hi andy_c! I use LTspice so how can I measure Slewrate?
Thanks!
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Old 4th February 2007, 04:21 AM   #4
Banned
Thanks!
Hi thanh,
Using transient analysis, apply a sine wave input so that the output is just below clipping. Now keep increasing the frequency of the sine wave until the output looks very distorted, like a triangle wave with sort of straight edges instead of curved. Right click on the V(out) expression (or whatever the name of the voltage at the top of the plot is) and in the combo box in the upper right, where it says "attached cursor", choose "1st & 2nd". This will give you two cursors. Drag them to two points on an edge of the triangle wave. At the bottom, where it says "Diff(Cursor2-Cursor1) take the data that says "slope" (which will be in Volts per second) and divide it by 1e6 to get volts per microsecond.
Old 4th February 2007, 04:38 AM   #5
thanh's Avatar
Thanks Andy_C!
Slew rate calculations - how much do I need? peranders Solid State 232 20th November 2011 06:02 PM
IcePower slew rate Rikard Nilsson Class D 24 29th April 2009 04:39 AM
slew rate adjustment... chipmonster Parts 7 25th January 2008 10:01 AM
Slew rate limit for SACD atalio Digital Source 11 23rd October 2006 06:41 PM
Slew rate value Luke123 Chip Amps 5 7th April 2005 12:30 AM
Page generated in 0.10535 seconds (60.50% PHP - 39.50% MySQL) with 10 queries
