I have a mosfet amp which is performing quite nicely -- THD is 0.003% at 1 kHz, 10 watts -- in testing it out I wondered whether the distortion might not just be an artifact from my test setup -- so I observed the distortion on the input capacitor -- when there is no power on the input stage the distortion is just a little higher than what you should expect of the SG505, i.e. 0.002%. (the SG505 when connected directly into the AA501 measures 0.0008% THD at 0 dBm). When I power up the input stage it shoots up to 0.007%, sometimes 0.010% -- i wonder what causes this little bit of unhappiness.
#2 |
Ground loop?
#3 |
Did it Himself
Maybe input offset current creating a small bias across the cap? If it's an electro then the bias might make a lot of difference.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Noise on the rails?
We could go on for ever.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
Nonlinear input impedance.
#6 |
Do you use a series R at the input? What if you short that?
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#7 |
I think that I have found the problem -- I switched to a Pomona cable to the input connector and connected directly to the input capacitor -- now the THD before and after doesn't change -- and it went down to 0.0022% -- this is using an 80kHz bandwidth.
#8 |
Hi J,
tell us more about the before and after cables
regards Andrew T. |
| Input transformer: floating input = distortion | ErikdeBest | Tubes / Valves | 13 | 20th January 2009 09:36 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| heavy distortion in sonic t-amp after input mods | pne | Class D | 8 | 24th May 2005 01:20 AM |
| Non Linear Distortion testing - Harmonic Distortion | JMB | Multi-Way | 0 | 20th July 2004 02:54 PM |
| Sloan: cross-over distortion vs. input voltage | millwood | Solid State | 17 | 21st September 2003 10:02 PM |
| Page generated in 0.08580 seconds (77.86% PHP - 22.14% MySQL) with 10 queries |
