Old 31st January 2007, 01:28 AM   #1
fab is offline fab  Canada
fab's Avatar
Default Lateral mosfet w Normal or Diamond buffer?
Hi to all
This time I would like to get your opinion on the differences between the Normal emitter follower buffer and the Diamond buffer to drive a Lateral Mosfet power output stage.
I will attached 2 amp schematics:
- one with Normal buffer
- other with Diamond buffer (same one as APEX PA52 device)
Except for the buffer to drive the output stage the rest of the amp is the same. According to the basic measurements I do with Microcap 6 simulator I can not see really the differences between both topologies.
For the diamond buffer, the low VGS off the output lateral mosfets, makes me use a simple VR for bias current (but with regulated supply) instead of the Vbe multiplier. Maybe I could use a low VGSoff lateral mosfet for this but I think that I would need to select especially low VGS off devices for that purpose...
I have read some other threads on the diamond buffers but thy use a current source in place of Q17 and Q46...
first the Normal buffer...
Please comment.
File Type: jpg amp_fab_normal_buffer_simple_rev_0.cir.jpg (77.1 KB, 2467 views)
Old 31st January 2007, 01:29 AM   #2
fab's Avatar
Default Now the Diamond Buffer version
...Diamond Buffer version
File Type: jpg amp_fab_diamond_buffer_simple_rev_1a.cir.jpg (77.4 KB, 2114 views)
Old 31st January 2007, 01:36 AM   #3
darkfenriz's Avatar
Maybe there is little difference, but you could adjust R130/R131 and R40/R42 in your second schematic assymetrically (smps-styled) to prevent any current spikes in output mosfets at fast slew or transient.
Old 31st January 2007, 02:53 AM   #4
fab's Avatar
Can you explain your reasoning or what criteria to use to adjust assymetrically these resistors?
Are you talking about cross conduction issue?
If there is little difference why APEX selling its Amplifier IC PA52(A) at such a high price? or is it the rest of its circuit or the overall?
Old 31st January 2007, 02:30 PM   #5
darkfenriz's Avatar
Yes, I mean cross conduction at transients. Aside from better discharging of gates and probably lower cross-conduction and slightly higher slew rate I don't know why diamond output should be pricier.
Old 1st February 2007, 12:44 AM   #6
fab's Avatar
Darkfenriz,
I am not following you here. First you say that the second schematics (diamond buffer) may have cross conduction but secondly you say that the diamond buffer is better for lower cross conduction...
Also, what do you suggest as resistor values for R130/R131 and R40/R42?
Old 1st February 2007, 02:03 AM   #7
fab's Avatar
Default New version 3B
Hi I have modified the diamond buffer as per http://www.elecdesign.com/Globals/Pl...tent/2800.html
The drawback is that for power amp with bias adjust I need 2 pots (VR1 and VR2)...
Any comments compared to previous 1A version (same diamond as APEX 52A)?
File Type: jpg amp_fab_diamond_buffer_simple_rev_3b.cir.jpg (82.4 KB, 1673 views)
Old 9th February 2007, 10:05 AM   #8
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Lateral mosfet w Normal or Diamond buffer?
Please comment.
Good question you put here, fab.
Same question can be asked for Bipolar Output stages.
I have began to use more and more Diamond!
I my simulations ... with great results, in compare to 'normal' Darlington outputs.
This is because of super results, when I did my clone of AD797 hifi Op-Amp:
See details in:
AD797 Clone people! Who can make a better one.
... and when I did my follow up, with 'an improved' Hifi Op-Amp
also using Diamond Output, like AD797:
New JFET Hifi Op-Amp release!
If this way of output stage, Diamond, works in preamps and Op-Amps
of course it will work great in some Power Amplifier applications, too.
And so it does.
There are people that have done excellent power amps this way before!
My thought:
- diamond output stage, with 2 drivers and 2 output power transistors
can not beat the gain of a triple darlington. Like in Leach Super Amp, for example.
But in some amplifiers we do not need as much gain.
And here I can not see any drawback using Diamond.
Not when compared to a usual 'Double Darlington' output. ( 2drivers + 2 output T )
Here are my current testings, fab
See Attachment Circuit.
I am designing a Class A amplifier with 100 Watt idle supply.
+/- 25 VDC and 2.0 Ampere current.
Results are very promising.
My first verson here, 1.0, is simulated with MJ15024/25.
I will try 'the better' MJL21193/94 and MJL3281A/1302A.
I have no doubt my figures will be improved. Those better devices usually lowers THD figures considerably!
I have no doubt!
Regards, lineup
Lineup Audio Lab
lineup
Old 10th February 2007, 12:29 AM   #9
fab's Avatar
Originally posted by lineup
My thought:
[/B]
What about diamond buffer at 20 ma and a pair or more of lateral mosfet power transistors?...
I have no doubt!
[/B]
Thanks lineup it is good to know that some peoples are interested in the diamond buffer...
You may have notice that the diamond buffer before the output transistors I am using is the same one as APEX (my revision 1A circuit) and not the Walt Jung one with current source(same as yours). It would be intersting to compare both diamond variations...
Your circuit looks quite interesting. I like jfet too for performance but they are always complicated to match or even get the proper IDSS current compared to bjt where only HFE parameter is used for optimization. I found that the "low memory" input stage with bjt I used is very linear too (simulation and real measurements too).
Please keep us informed of your simulation and prototype results.
On my side I have a version (based on my revision 1A circuit) on breadboard powered by only 28 Vdc with limited current. THD is about 0.1 % in 16 ohms which is high for me but I think this is a breadboard/power supply/grounding scheme problem. I am working out a pcb layout in paralel. I plan to maybe connect a more higher current capability power supply at 40 Vddc to see if my current bias for each stage is sufficient....
Old 10th February 2007, 01:00 AM   #10
lineup's Avatar
I don't know how you think 'diamond buff + lateral' would be setup ..
Actually I was a bit wrong, that you can not use
Diamond at 3 stages, to match triple darlington gais.
You just make, driver a sziklai pair. Or make output use sziklai config.
But this is only if we need high gain and low load, burdon, onto VAS stage.
Your 0.1% breadboard might be something! With some tweaking.
Here I quote Hugh AKSA Dean:
'An acceptable level of distortion for my power amplifiers is THD 0.05% or less.'
And what I know, there is no valid listening tests
proving that humans can hear lower distortions, than 0.1% THD.
So I say, AKSA is well in line with reality here
You may have a look at my latest Diamond Follower, 500mA Class A.
I designed it today and did virtual simulation tests to refine it.
In the Pass Labs GRollins topic:
MOSFET follower headphone amplifier
In my own HUMBLE Opinion:
Post #44 is the most interesting and innovative in that Topic, so far
... MOSFET single device followers, there are 20 by the dozen around already
lineup
lineup
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
diamond buffer for car project djronbxs Solid State 0 17th November 2007 01:06 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 05:58 AM
what about diamond buffer MOSFET? padamiecki Solid State 26 5th October 2005 03:55 PM
Diamond buffer peranders Solid State 45 15th November 2003 11:00 PM
Page generated in 0.13352 seconds (86.21% PHP - 13.79% MySQL) with 11 queries
