What's the highest power amp you've built?
Old 30th January 2007, 06:15 AM   #11
Danko is offline Danko  Hungary
Have you tried discharging that capacitor bank with a screwdriver? :-D
Best regards, Danko
Old 30th January 2007, 12:00 PM   #12
AMV8 is offline AMV8  United Kingdom
Hi
The biggest I have built;
In class A, 60watt, 75watt and 100watt class A monoblocks.
In class A/AB I have made classA to 40watt/class AB to 200watt amplifier.
For me the power is limited by the physical size and weight ( around 80lbs )
I do have some electrocompaniet Electro 25's and Kelvin labs 30 watt class A amps that I use occasionally. I have upgraded both and given them regulated power supplies on the front end and more final stage power reserve. They are great on voice and provide tremendous detail. However I still prefer to listen to a around 100watt class A or A/AB amp. It just seems to give a more balanced sound to me.
Don
Old 9th March 2009, 02:04 PM   #13
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
5000 watts RMS output but with transmitting triodes. That kind of high power with tubes is relatively easy and you can do it with a single tube. I respect that to make that much power with silicon is WAY harder to achieve.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 9th March 2009, 02:54 PM   #14
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by esorcc What's the highest power amp you've built?
Half a fathom.
Old 9th March 2009, 03:18 PM   #15
wg_ski is offline wg_ski  United States
1500W/2R - front end resembles a Lynx but phase splitter is common emitter (similar to Carver and early Crown and PV), outputs resemble the S-Leach - class AB (monoblocks) and class G (stereo). I've used these for years.
900W/2R (x4) - finished and working class H prototype - similar circuit to above, but with upper slave banks replaced with the QSC rail switch.
2000W/2R (x2) - target for new amp in progress. 3-tier version of the above prototype with extra outputs, much better PCB, and full supply supervisor, thermal protection, and front end processing. Building four identical units simulatneously.
Highest power class A - Nelson Pass' old 1977 design with 2N6259 outputs (8 per bank) running off a Signal 80-25. 125W or so monoblock. Breadboard prototype only - will go back and re-build permanently one day after I build the wind turbines to alleviate the utility bills. I kept the 25W version.
Old 9th March 2009, 04:51 PM   #16
Samuel Jayaraj is offline Samuel Jayaraj  India
500w into 4 ohms, bridged to 1KW into 8 ohms. Elektor design using Lateral Mosfets for OPS.
I have assembled some yet untested boards which can do 1200watts into 4 ohms in Class G. They use bipolar outputs. Hope to find enough time to test these and put them into suitable cases.
Sam
Old 9th March 2009, 05:03 PM   #17
Steve Dunlap is offline Steve Dunlap  United States
Steve Dunlap's Avatar
Originally posted by Nelson Pass
4 KW
I think I saw that at CES one year.
My highest so far is 1600W at 8 ohms. Yes they were for pro use.
Old 10th March 2009, 05:54 PM   #18
rayfutrell is offline rayfutrell  United States
I used to design control systems. The last amplifier I worked on was to drive 50 HP servo motors and would put out +-400 volts at 200 amperes. We had a 10KW dummy load consisting of series-parallel connected heater strips that are used in heat pumps.
Old 10th March 2009, 07:28 PM   #19
rcavictim's Avatar
Too bad brain dead youth aren't more financially endowed. Your company would have had a huge market for that amplifier technology to power automotive subwoofers.
Old 10th March 2009, 07:39 PM   #20
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I did dredge up a couple of photos.
What's the highest power amp you've built?Hide this!Advertise here!
Question about power amp built in high pass filter crippledchicken Solid State 0 22nd October 2008 06:09 PM
Has anybody successfully built any Bryston power amps? Renx Solid State 19 7th June 2007 09:41 PM
Highest Power, Single Supply Chip?? Zero Cool Chip Amps 1 19th June 2005 02:49 PM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 12:11 PM
Highest power dissipation JFET? Petter Parts 7 26th February 2003 09:21 AM
