I instaled new power transistors in my ka-5500 and they are very hot after few seconds. How to set them?
please help |
#2 |
Do you have a schematic or a pic of the board? Can you identify the bias adjust pot?
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
please help |
#4 |
Did it Himself
Jan has already responded, asking the question again and ignoring his useful advice is not going to get you very far.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
And are you sure that:
1) Power transistors were the only part that needs change? 2) That the BIAS was set to the lowest position prior to installing new transistors? |
#6 |
Sorry I thout, that I wrote this post in wrong place and I write it again in other place. Probebly moderator changed this and paste it here. This schema is to big i added onely a piece of it. There are variable resistors (BIAS) but i don't know what voltage on which element should be. Power transistors are 23, 24, 25, 26.
BIAS are not on the lowest position. sorry Jan thanks for help |
#7 |
Did it Himself
You need to turn the bias pot so that the voltage across the output device emitter resistors is as low as you can get. This will mean setting the pot to lowest resistance.
Then increase the pot a bit at a time. You need to aim for about 25-33mV across the output device emitter resistors.
#8 | |
Hi richie00boy Everything you wrote is correct , except that for minimum current across the output devices , the pot must be set at is highest resistance value.
Jorge |
#9 |
Did it Himself
Yes sorry, squinting at the schematic I got the transistor the wrong way round.
#10 |
Thank You very much.
| Kenwood KAC-8152D no power | tritron | Car Audio | 2 | 14th May 2008 05:52 AM |
| kenwood kac8401 no power | lalo01 | Car Audio | 20 | 24th October 2007 06:34 PM |
| Looking for a Kenwood L-07MII power transformer | Klaude | Swap Meet | 3 | 7th February 2007 02:04 AM |
| KW-40 by Kenwood power amp/tuner? | RMS | Analogue Source | 5 | 5th January 2003 10:58 PM |
| Page generated in 0.08765 seconds (79.41% PHP - 20.59% MySQL) with 11 queries |
