Today, I finished building my first amplifier kit. The kit was from Future Kits. It's a stereo power amplifier kit. Basically it came with two identical modules. I finished building the amps today. I'm still waiting for the power supply components to get here. I bought a 35-0-35V, 300 VA EI type transformer from a local parts supplier. They had to order it from Hammond. I also bought a nice rack-mount chassis to put the finished amp in. I have two 19000 UF caps for the power supply. 19000 UF per rail seems like enough. Also I bought two 10K audio taper pots for volume controls.
Anyway, specs on the amps
type: Full complementary Class AB
power: 100w rms into 8 ohms.
distortion: 0.02% THD
Frequency response: 10 Hz to 100 KHz +-1 Db
rail voltage: +-50 VDC
Hopefully I can send out some photos of the completed amp.
When undertaking the internal wiring:
1. As you have mains input, E-I transformer and high-ish current rectification in the direct environment consider using a screened cable from the line input socket to the volume control and then to circuit board.
2. As a starting point use reasonable gauge wire in the power supply, such as 14 awg.
3. Position your power supply filter capacitors close to the output transistors. If they are more than a couple of inches away then twist the positive and negative cables together to reduce inductance.
Good luck with your project.
As of now, the mains voltage is 120 volts right on the nose. The transformer's primary voltage is actually 115 volts. How much difference would that make on the output? To go from 115 to 70 volts is almost a 2 to 1 ratio, 4 to 1 on either side of the center tap. Five extra volts on the primary would probably bump the secondary up slightly.
Bama Slamma said:As of now, the mains voltage is 120 volts right on the nose. The transformer's primary voltage is actually 115 volts. How much difference would that make on the output? To go from 115 to 70 volts is almost a 2 to 1 ratio, 4 to 1 on either side of the center tap. Five extra volts on the primary would probably bump the secondary up slightly.
Don't worry. Mains tolerance should be accomodate variation of about +/- 20% on the nominal voltage. If your kit is well designed (i.e. equipped with component rated about 1.5 times the actual working voltages) this tolerance is not a concern at all.
Piercarlo
It Works!!!
I got the transformer today and wired up the power supply. The transformer was actually a 30-0-30V transformer. With 120VAC input, it was reading 32-0-32V. The fully assembled supply measures +/-45VDC. I wired up one amp to the supply and powered it up. The amp was so quiet I didn't even think it was working until I touched the input with my finger, causing a buzz to come out of the speaker. I cannibalized a set of cheap headphones for the cord and used a Discman as the source. Upon hitting PLAY, a deafeningly loud, heavily clipped version of Tchaikovsky's 1812 Overture came out of the cheap speaker I was using to test the amp, followed by a puff of magic smoke from the speaker as it gave up the ghost (the speaker, not the amp). I hooked up a better speaker to the amp and reduced the volume on the CD player. Result: Beautiful Music! I hooked up the other amp and fed it with the other channel. Result: Beautiful Music In Stereo! With this success, I'm definitely addicted to building audio products. It looks jerry-rigged now, but I have a very nice chassis on the way to mount the amps in.
Re: It Works!!!
DIYaudio hooks another victim...
Bama Slamma said:... I'm definitely addicted to building audio products. It looks jerry-rigged now, but I have a very nice chassis on the way to mount the amps in.
The Chassis is Here
The chassis just arrived in the mail today. I'll mount up everything in it tomorrow. The chassis will mount in a standard 19" equipment rack. I'll have to plan everything out. It's easy to drill a hole but very difficult to fill one back in once a hole has been drilled in the wrong place. I'll post some pics once the amps are in the chassis.
amp pics
Well I finally got my pictures ready. Apparently they were over the 104K limit for attachments, so I shrank 'em down. Well without further ado, the pics showing the amp both in the testing and completed stages. This shot is initial testing on the kitchen counter. The red towel is for insulation purposes.
Re: amp pics
Be careful about unwanted noise due to common supply simultaneously for the two channels. Are you sure that don’t exists ground loop? Check it by grounding the inputs or turn the volume controls full counter clockwise. Under complete quietness put your ear above the cone of woofer. Hear then carefully if exists any buzz. If it is so, report this to help you resolve this problem. Be careful about idle current if it is remain stable after one hour of operation without input signal and with the inputs grounded. Afterwards you can hear all music you want.
Dear Bama SlammaBama Slamma said:Well I finally got my pictures ready. Apparently they were over the 104K limit for attachments, so I shrank 'em down. Well without further ado, the pics showing the amp both in the testing and completed stages. This shot is initial testing on the kitchen counter. The red towel is for insulation purposes.
A GND loop can be a nightmare If you could gain access to an O-scope & function generator, it would allow you to see if the amp is stable, accross all loads, particularly capacitive. Do a square wave test... around 1KHz at 100-500mV driving caps ranging from 1nf to 10uf. Look for any overshoot or ringing.
Apparently there are no ground loops because with no signal applied the amp is DEAD quiet, not even any audible hiss in the speakers, much less any hum. The only "hum" audible is from the power transformer and even that you have to be less than a foot away to hear it. The amp runs very cool. With no signal, the heatsinks stay at ambient temp. They feel cool to the touch. The output transistors (Toshiba 2SC5200 and 2SA1943) themselves stay cool to the touch. Even running the amp hard (at the threshold of clipping), the heatsinks only become just barely warm to the touch and that's after several hours. When playing, the sound is clear as a bell. The amp will play cleanly at low volume for about 30 seconds after turning off the power before the filter caps discharge.
- My First Amplfier
