Old 28th January 2007, 12:32 PM   #1
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Default A Transconductance Amplifier
To start, I'm not trying to steal Mr. Pass's idea for a transconductance amplifier. Of course, my implementation is far different from his to begin with.
I've begun developing a transconductance amplifier for my own personal use and thought I'd like to talk about it.
I'm using a three-stage design with error amplifier, so this does have feedback, and is more like a typical three stage voltage amp than anything. The major difference is that the feedback loop is now with a speaker in place of the feedback resistor, so that it senses current drawn through the speaker.
For the prototype, I'm using an op-amp to drive a push-pull output stage. This is done through an emitter follower which is loaded by a current source to drive the output transistors. Nothing new here.
My desire to do this was merely out of wanting to see how a transconductance amp acted. I'd never used one for driving loudspeakers before.
To say the least, the results are absolutely astonishing. As I have studied, the effects of a lot of internal speaker limitations are more or less taken care of. It really is something else.
If anyone would like to see what I've done exactly, I suppose I could post a schematic.
Old 28th January 2007, 02:27 PM   #2
fab is offline fab  Canada
fab's Avatar
Default Re: A Transconductance Amplifier
Originally posted by Duo
...I've begun developing a transconductance amplifier for my own personal use and thought I'd like to talk about it.
...If anyone would like to see what I've done exactly, I suppose I could post a schematic.
I suppose I would like to see it...
Do you have any test waveform results?
Old 28th January 2007, 03:46 PM   #3
latala is offline latala  United Kingdom
I suspect this will have been done before i can think of a few examples but i would like to see a schematic values dont have to be shown!
Then i will be prepared to pass opinions / comments
regards trev
Old 28th January 2007, 03:53 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
About 15 years ago, in the beginning of the 90-ies, I think,
Elektor had such an amplifier.
I could find this article and post a copy of schematic.
I have all them old Elektor magazines stored here.
The basic and rather simple circuit can be seen in my attachment.
I have drawn this schematic from memory.
It shows the Current Feedback princip.
The Gain in this case is: LSP 8 Ohm / 1 Ohm = 8
lineup
lineup
Old 28th January 2007, 04:15 PM   #5
hacknet is offline hacknet  Singapore
ive done that with an lm3875..
the results were pretty good, super bass but i found the mids to be extremely hard and the there seemed to be a rising highs, i think it is because of the rising impedance curve of the single driver.
all it required abit of a filter and it was pretty nice.
Old 28th January 2007, 04:16 PM   #6
there is a more efficient way by having 2 feedback loops and the sense resistor at the output, that way you wont have a floating output problem.
Old 28th January 2007, 04:36 PM   #7
lineup's Avatar
Yes,
this is probably the way to do it, hacknet.
My attachment is not a complete design circuit.
As I told, it is a simplified diagram - to show the basic princip.
Actually this is what I would call A True Current Feedback Amplifier.
CFA - In the correct sense.
Because gives an output current proportional to input voltage.
One thing about woofers/speakers to use with this.
You may have to rolloff the rising impedance of the speaker.
Using some impedance equalizing filter.
Similar in effect to the Zobel Network.
Say the impedance would rise to 30 Ohm in higher freq.
The gain would be also 30!!
Regards, lineup
lineup
Old 28th January 2007, 05:01 PM   #8
Regards, lineup
Don't know that much about amps, but I think I might have caught a small error here.
If the normal impedance of the speaker is 8 ohms, and it gradually rises to 30 ohms, wouldn't the gain be 30 / 8 = 3.75?
Which would still be considerable, and very hearable, but not as high as if the gain were 30.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 28th January 2007, 05:54 PM   #9
lineup's Avatar
See my attachment:
http://www.diyaudio.com/forums/attac...amp=1170003209
The gain is: LSP-Z / R3
R3 is in this case 1 Ohm.
So, Nominal gain is: 8/1 = 8
At Z=30 Ohm ...... 30/1 = 30
This is why we need to watch out, that speaker impedance stays within a reasonable level.
Nelson Pass, for his First Watt amplifiers, suggested simply a resistor in parallel with the Loudspeaker.
It will work.
But I prefer use a Impedance Equalizing Network:
Le is the inductance of your driver's voice-coil (in henries).
Re is the D.C. resistance of the voice-coil (ohms).
The design equations for this type of filter are:
Capacitor = Le/Rc2
Resistor (Rc) = 1.25 X Re
Websource:
Zobel Loudspeaker Impedance Correction Circuit
lineup
Old 28th January 2007, 06:12 PM   #10
I have seen something like this in the 1970,s I think a company called servosound did this allthough in that case it was a mixture of both voltage and current feedback !
I have also seen H+H amplifiers use a degree of current feedback with very good results
Rod Elliot The Ausie has an article that relates to this on his web site !
Always worth a visit
Just remember when dealing with the amplifier spk combination a moving coil speaker is not only a varying impedance but can also be a generator ie a negative impedance such as at times when the cone/coil overshoots and for this reason I believe your ampifier may excert better control
regards Trev
transconductance power amplifier for current-drive loudspeaker? alex0 Solid State 30 26th May 2008 08:15 AM
LM3886 as transconductance amplifier? squadra Chip Amps 4 23rd April 2008 10:16 PM
[transconductance] error amplifier section of UC2526 zilog Power Supplies 0 21st January 2007 11:40 PM
A SOZ Transconductance Amplifier gl Pass Labs 21 16th December 2005 07:42 PM
commercial high-power transconductance amplifier! taloyd Subwoofers 10 5th August 2005 04:02 AM
Page generated in 0.12368 seconds (82.18% PHP - 17.82% MySQL) with 11 queries
