NAD 2140 Problem
NAD 2140 Problem
Old 27th January 2007, 09:09 PM   #1
Aquarium is offline Aquarium  Australia
Default NAD 2140 Problem
I have a NAD 2140 Power Amp that started giving me strange problems.It blew a couple of it's 3.15 Amp fuses on the PCB after distorting sound started coming from the left channel only.I replaced all 4 3.15 Amp fuses and it seems fine powering up but the noticeable distortion coming from the left channel is still present.Any help or ideas would be appreciated?
Old 27th January 2007, 09:45 PM   #2
es44 is offline es44  Denmark
es44's Avatar
Most likely it's the driver or output transistors that's blown. If you look at the schematics, the 3.14A fuses are sitting to ( try to )protect those. They will blow again if you krank it up a bit.
Oh yeah, if you don't have the schematic, then drop me a PM, then i'll send it to you.
Good luck
Ebbe
Old 28th January 2007, 12:05 AM   #3
Thanks,I have that schematic already.I have replaced all fuses on the PCB and I have the amp sitting on with a multi-meter attached to the speaker output measuring the DC from time to time.It seems to have stabilised around 4mv each side which is O.K. I will have to listen again I guess.Can I just replace the left channel output transistors and hope for the best?
Old 28th January 2007, 08:38 AM   #4
es44's Avatar
Well, maybe i'm a litlle too fast to call them dead. It doesn't sound too bad with that kind of dc-balance.
Maybe it's just a coincidence that the fuses blew. Maybe it could be some of the capacitors beginning to dry out ?.
It's a little bit hard to guess without further measurements. A scope and a ESR-meter would be a great help.
Old 28th January 2007, 06:13 PM   #5
Yes,I hooked up a radio to further investigate and the DC in the left channel shoots right up when under load with quite wide fluctuations,the right channel is o.k.Time for the shop I think.
NAD 2140 ProblemHide this!Advertise here!
NAD 2140 overheating resistors Ardvaark Solid State 0 6th July 2009 02:04 PM
Experience with Alian 2140 drivers? brucemck2 Multi-Way 1 28th February 2009 05:07 PM
Looking for a NAD 2140 schematic pto892 Solid State 2 26th July 2007 06:50 AM
Alian 2140 midrange ScottG Multi-Way 0 13th July 2006 11:02 PM
Need NAD 2140 schematic Frank10 Solid State 0 16th August 2005 06:49 PM
