I'm looking to replace some toasted-looking transistors in a Musical Fidelity B200 but am having trouble sourcing two of the small transistors. Here's the schematic:
![]() The offenders are TR1 through TR4, but I can easily find the TIP32C and TIP31C. The ones I'm asking about are: TR2 - BC416C TR4 - BC414C Here's a shot of TR4. TR2 is the exact same package. ![]() Any help would be greatly appreciated. |
#2 |
Well, seeing as how they are uses as a CCS, they could probably be replaced with any small signal part such as a BC850 or BC856, just make sure the pins are the same. If you use a fast transistor, you might include small cap(100pf) across collector to emitter to prevent oscillations.
All the trouble I've ever been in started out as fun...... |
#3 |
http://www.datasheetdirect.com/pdfs/1123128/BC416.pdf
Hopefully this datasheet displays.It has both BC414 & 416...Nuts it dont . Register at this site.Its free factsheets ,search # 83 for BC416 and both 414 and 416 come up
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#4 |
ok, thanks
| NEC transistor equivalents, for old NAD amp | Hamish | Solid State | 28 | 21st February 2007 04:27 AM |
| Transistor equivalents | merbert | Pass Labs | 3 | 3rd July 2006 08:11 PM |
| Thershold transistor equivalents/substitutes | Nickolas K. | Solid State | 3 | 1st July 2006 02:02 PM |
| 6F1 and 6P2 Equivalents | fmak | Tubes / Valves | 1 | 27th September 2005 05:17 AM |
| Help with Equivalents | DieterD | Parts | 2 | 1st October 2003 10:58 AM |
| Page generated in 0.07290 seconds (77.32% PHP - 22.68% MySQL) with 10 queries |
