Old 23rd January 2007, 06:32 AM   #1
Question ROTEL RB 956AX Voltage Conversion
I recently purchased a ROTEL RB 956AX 110V. I would like to change its voltage to 220V. Could anybody help by giving me some tips or by sending me a service manual which probably will give me the instructions that I need? Thanks
Old 27th January 2007, 02:36 PM   #2
docfin is offline docfin  Europe
Account Disabled
Service manual for RB-956AX available here: http://service-manuals.webs.io
Old 27th January 2007, 04:11 PM   #3
TDWesty is offline TDWesty  Canada
Default Re: ROTEL RB 956AX Voltage Conversion
Rotel in North America will provide service manuals by email at no charge - I got one for my RCD-965BX CD last week.
I converted this unit from 220 to 110V without the manual -it's clearly marked on the transformer. Not sure if the amp would be the same though...
Shawn
NAD 3125 & 3020 amps, 4125 tuner / Rotel RCD-965BX CD / B&O 2400 / Nakamichi BX-125 / PSB 70R speakers / BrianGT chipamp in progress...
Old 23rd March 2007, 10:44 AM   #4
Nrik is offline Nrik  Denmark
Bought one Rotel RB-956AX used.
Two pairs of outputs were gone, and one speaker terminal was broken.
Got hold of the original transistors and fixed everything. It works great.
But:
The Idle current in all the outputs were set to 160mA. I think this is quite high for this amp so i re-adjusted it to 100mA.
I am suspecting the previous owner turned it up for lower distortion, but this could be why it burned the two outputs.
Does any one know what the Idle current is supposed to be?
Old 19th July 2007, 01:55 PM   #5
tazmc is offline tazmc  Norway
Nrik
were did u get hold of the transistors for the Rotel RB-956AX.
Need that and 2 resistors(big one) 1 chanel is gone.
Old 19th July 2007, 04:54 PM   #6
Tazmc
The original transistors are discontinued, so you have to look for NOS = New Old Stock
I was lucky that a small company in Copenhagen (not even email) had both drivers and outputs. You should try and call him, I am shure he can ship to Norway also.
A/S Telmo Elektronik.
Dronning Olgas Vej 24
2000 Frederiksberg
Telefon: +45 38103255
Old 19th July 2007, 04:57 PM   #7
...and check your driver-transistors before putting in new output transistors. If the drivers are gone too, the new outputs will blow again.
BTW: in another thread I was told that original bias should be about 45mA
Old 9th February 2010, 06:59 AM   #8
schro20 is offline schro20  United States
schro20's Avatar
Default Looking for RB-956ax service manual
I tried that web address posted earlier in this thread, but it appears not to be in place anymore. Does anyone have this manual on hand? or know where to download it? I just acquired this amp. Very nice indeed! But I am thinking that maybe a little restauration work is called for. A circuit diagram would obviously help... Any suggestions?
Thanks much!
Peter
Dlink NAS -> Roku M1000 -> DAC -> MJR7-mk3 -> Nagaoka 113 -> Ears
Old 9th February 2010, 08:04 AM   #9
schro20's Avatar
Default Found it! (RB-956ax technical manual)
I found the technical manual for RB-956ax at The Audio Circuit
Had to upload another to get it (they run some mutual exchange program, it seems).
Peter
Old 25th October 2010, 02:33 AM   #10
schro20's Avatar
Default going from 220V to 110V
I am back in the US and need to convert this baby to 110V. The circuit diagram shows the toroid to have a single primary with 4 taps. Only one of them is named with color in the diagram: white (the "bottom" tap). AC8 is currently connected to blue. The ordering of the wires coming off the toroid is white, orange, blue, brown.
I just put 118V (my local voltage) on the machine and took measurements against the white wire. Blue shows 118. Brown shows 123 (how can that be???) and orange shows 61. Looking at the ratios I want the orange wire to connect to AC8. That requires soldering. I am ok with soldering I am just surprised that this beast is built in such a way that soldering is required to switch voltages. They have terminals for all 4 wires. Its just that for different countries I guess the colors going to AC8 (active) AC7 (just a node on the circuit board with no connection anywhere and currently holding the orange wire) and AC9 (also no connection on the circuit board just holding the brown wire) would need to be changed. Weird.
So it looks like orange should be put on AC8 and then blue moved someplace else (I suppose I can put it on AC7). But is that what they really intended? Does anyone have a 110V version of this amp and wouldn't mind looking inside and checking (or maybe even posting a photo)? I would be most grateful.
peter
fpb 300 voltage conversion from us to uk? patbarrydub Solid State 5 5th December 2011 01:00 PM
Rotel RMB1048 110V 230V conversion tomekajja@yahoo Solid State 5 4th March 2008 10:06 PM
Voltage conversion? mmx_2 Solid State 0 28th December 2004 12:25 PM
Voltage conversion: US to UK? diaspora Parts 3 3rd May 2004 08:09 PM
voltage conversion mike moore Everything Else 4 10th February 2001 07:43 AM
Page generated in 0.10319 seconds (82.53% PHP - 17.47% MySQL) with 10 queries
