Can a series fuse of say 5A protect speakers from damage from amplier fault?
I want to protect my speakers during DIY changes as simple as possible..... |
#2 |
No, Highly reccomend building a proper spkr protect ciruit with a spkr cutout relay.Similar to
http://sound.westhost.com/project33.htm.............;)
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
Agree, Xeaglekeeper! A big NO!
(And the fuse produces audible distortions too...) |
#4 | |
Also look up a uPC1237HA IC, it's an speaker protection, anti thump on-off, and more. |
#5 |
That is a neat chip! Thanks ifrythings.
#6 |
Have you used it?
#7 | |
Not yet, but I do have 10 of them on my bench staring me down I have a Clarion car amp schematic that uses one of them for the protection, but they don't use an output relay. |
#8 |
ESP P101 "They Rock"
#9 |
Why does a fuse not protect sufficient?
Why do speaker woofers burn with DC? |
#10 | |
The fuses are too slow, they take time to heat up and then snap the wire in it glass tube. As were a protection IC can do this 1000 (or more) times faster then a fuse can It also doesn't need to be replaced, it's not prone to nucense blows and can trip at 1V offset or less(as were a fuse requires many volts before it opens). A speaker is a AC device, to put it basicly if you put in 1W of audio signal(AC) into a speaker, it will put out 1W of sound vibrations (this is extremely simplifed) but if it gets DC all it can do it pop in or out and the 1W of DC (for example) will turn into heat and not sound waves. If the DC is Large enough the speaker will be damaged before the fuse even knows whats happening. |
| loudspeaker protection relays? | h_a | Parts | 8 | 4th September 2008 07:43 AM |
| Loudspeaker protection | harrisni | Solid State | 5 | 23rd August 2006 04:32 PM |
| Loudspeaker protection kit | Vivek | Multi-Way | 98 | 5th September 2003 07:49 AM |
| Page generated in 0.09535 seconds (79.84% PHP - 20.16% MySQL) with 11 queries |
