I have a HK3380 stereo receiver that the cat urinated (not sprayed) on and fried the main circuit board including the big cans. I was mad, but I maintained because it was my fault for not covering with a case of some type. Stupid me! So in a fit or rage (ya, that's probably what it was), I stripped that puppy down all the way. I have the back and bottom of the case put back together and the power supply back in. I have hugh aluminum heatsink with aluminum fins on the back of the plate aluminum. All urine is now cleaned out. That's my long story in short mode.
The transformer states 250V 6.3A with a CT. I took my DMM and measued the AC across the blue and red and it was 73.5. I also measured across the black and then the blue and each read 1/2 of that 73.5VAC. I then went to the ESP pages, asked numerous questions on the PE board and overwhelmed them. I should have went slower. Using the ESP pages as reference I used the formulas and figured that this is a EI 50-0-50 transformer. Probably more like 45-0-45 after ripple effect, diodes, etc. My first question is did I do the math right? If so, then I have enough heat sink area to place two of the ESP High Power Version mosfet PCBs on the sink. So I think I have chosen the right kit and have enough transformer to driver it right? I am not an EE, but a hobbiest. I pick things up quickly but will need some help and guidance along the way. There will be stupid questions for you but not me. This is my first post, so I just want to let you guys know what I want to make and need help. The boards will be ordered payday via paypal. I've been told that I must get a Variac for testing to bring up the power slowly so that I don't burn the house down, fry diodes, amps, etc. I will search for one of those and buy one. That's a little further down the road though. My next step is to buy a screw mount fuse holder. I will wait until I have that but I have some a question on hookup later. At some point, I hope to make contributions to this board instead of sucking in information. Thanks for acepting me guys~! Here are a few links to show the progress from this weekend when I started the rampage. [url]http://home.stx.rr.com/poneal/TransformerInTheStrippedDownCase.jpg[/rul] http://home.stx.rr.com/poneal/heatsink2.jpg Paul N. O'Neal |
#2 |
#3 | |
you measured an AC voltage of 73.5Vac and two voltages of ~37Vac. This indicates a transformer running at slightly higher than 70Vac centre tapped with a bit of regulation which is quite normal. After rectification it should give about+-51Vdc to +-52Vdc A variac is nice to have. A mains light bulb in series with the live lead is a MUST HAVE. Build one with a plug top and socket outlet to allow safe switch on of any new build or maintained unit. And keep it where you can find it easily.
regards Andrew T. |
#4 |
#5 |
The xformer should be beefy enough for the ESP P101.Nice sounding amps!
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#6 |
How would the P101 perform with a 300VA 30+30VAC toroid (+/-42vdc) supply into 4ohms? I got the transformer for a different (BJT) design but am seriously looking into the P101 if it will work properly; can't see why not really, should be over 120W or so?
#7 |
It would be feasible take a look at Rod's article
http://www.sound.westhost.com/project101.htm I used a 800VA 50-0-50 and 44,600uf per rail. My NS-1000's although 8 ohm, don't even get the smallish heatsinks warm at a sustained earbleeding volume level.These amps kick " gluteous maximus" Dave
#8 |
Cool
. A slightly obscure question about it but does it make much of a bang when switched on? You wouldn't need any speaker switching?
#9 |
Not a bit.The only noise when powering on is a momentary(<500msec.)transformer buzz with slight dimming of the overhead lights
It was a little worse before I installed the "softstart"P39.But never any power on/off speaker thump. One of my next upgrades is to install speaker protect circuit P33.For "just in case" piece of mind... Dave
#10 |
Ace, my 300VA shouldn't be a problem at all (with 20,000uf per rail). I bought a 50W resistor just in case but everywhere reckons I'd get away without soft start on 300VA
How much was the board in total (with postage). I can get the components quite readily so reckon i'll go with this amp over the K8060 kits I was going to use. It's for a sub, decided the damping on the K6080 might be a bit poor and have heard only great things about the P101 (like tight, controlled bass) Also quickly, will 0.5c/w heatsink suffice for this amp in the configuration I intend (as a couple of posts back)? I doubt i'd often go near full output anyhow so suspect it's plenty but anyhow |
| Voltage rating of p-channel MOSFET | Tahmid | Power Supplies | 7 | 3rd July 2008 08:10 AM |
| Transformer Rating | sushi | Pass Labs | 12 | 15th August 2007 04:05 PM |
| Transformer VA rating?? | RyanW | Power Supplies | 6 | 11th November 2006 10:23 PM |
| Transformer VA Rating vs. Current Rating | JhonDoe | Chip Amps | 45 | 5th June 2004 01:11 AM |
| Transformer rating, to DC | azira | Solid State | 4 | 16th December 2003 04:41 PM |
| Page generated in 0.62169 seconds (18.16% PHP - 81.84% MySQL) with 11 queries |
