#401 | |
#402 |
REGISTER ENTRY FOR GB2424137
Form 1 Application No GB0505024.0 filing date 11.03.2005 Title AMPLIFIER Applicant/Proprietor AUDIO PARTNERSHIP PLC, Incorporated in the United Kingdom, Gallery Court, Hankey Place, LONDON, SE1 4BB, United Kingdom [ADP No. 07018526002] Inventor DOUGLAS SELF, AUDIO PARTNERSHIP PLC, Gallery Court, Hankey Place, LONDON, SE1 4BB, United Kingdom [ADP No. 09246794001] Classified to H3W H3T H03F Address for Service MAGUIRE BOSS, 5 Crown Street, ST IVES, Cambridgeshire, PE27 5EB, United Kingdom [ADP No. 07188725001] Publication No GB2424137 dated 13.09.2006 Examination requested 11.03.2005 Grant of Patent (Notification under Section 18(4)) 16.01.2007 Publication of notice in the Patents and Designs Journal (Section 25(1)) 14.02.2007 Title of Granted Patent AMPLIFIER __________________________________________________ ______________________________ 15.06.2006 Notification of change of Address For Service address of MAGUIRE BOSS, 5 Crown Street, ST IVES, Cambridgeshire, PE27 5EB, United Kingdom [ADP No. 07188725001] to MAGUIRE BOSS, 24 East Street, ST IVES, Cambridge, PE27 5PD, United Kingdom [ADP No. 07188725001] dated 08.06.2006. Written notification filed on GB2373569 **** END OF REGISTER ENTRY **** __________________________________________________ ______________________________ RENEWALS DATA Date Filed 11.03.2005 Date Not in Force Date of Last Renewal Year of Last Renewal Next Renewal Date 11.03.2009 Status PATENT IN FORCE
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#403 |
Hi PMA,
10kHz is approx 60mV/uS/V, input or output, nothing approaching infinite about that. For an amplifier to be accurate to the limits of an audio source it must of course have a much greater bandwidth and short propagation delay if it is to be expected to damp real world loudspeaker back-EMFs at such frequencies - as can be generated by loudspeaker system crossovers. This is why it is essential to preserve output stage damping linearity throughout the AF range for class-AB operation, or to use some form of class-A augmentation. If a class-AB amplifier tests out better with a suddenly starting 10kHz sine (no matter whether this might be thought unrealistic) then it is also likely to be capable of establishing a more stable stereo image of an instrument like a cymball or violin due to either or both amplifiers being less disturbed by back-EMF. |
#404 | |
Thanks, Graham. Can we get a copy of your EW article? I'd also like to see the schematics of the amplifiers you refer to in your simulation so I can better understand what's being done. In regard to Self displacing the crossover point away from where back EMF has an influence, would that perhaps not be the same as running the amplifier in Class AAB, where it is in Class A up to between 1 and 10 watts, or so? Or is Self trying to achieve the same effect without the consequent increased idle bias power dissipation? Cheers, Bob |
#405 | |
Bob, That's part of it. In the whitepaper I refer to above, there is a table comparing efficiencies of A, AB, and XD in several incarnations. http://www.cambridgeaudio.com/assets...r8-2-06web.pdf Jan Didden
#406 | |
I can't argue with this, but I think it is not much different than saying that the small-signal bandwidth must be greater than 100 kHz or so, and that the amplifier have adequate slew rate, which, in the extreme case here, might be enough slew rate to handle a full-power 100 khz sinewave, in very rough terms, if the 10 kHz sudden tone burst were bandlimited to 100 kHz. I think that only comes out to about 24 V/us for a 100 watt amplifier. Neither of these requirements is asking a lot for a decent solid state amplifier. Bob |
#407 | |
#408 |
Hi Bob,
In his '90s texts Doug showed how there would be a transconductance change going from class-A to AB (not recommendable). He also achieved highly linear circuits when driving resistors, but there were comments about distortion when driving real world (back-EMF generating) loudspeakers. His class-A XD arrangement allows him to use his established highly linear class-AB circuits for driving loudspeakers because the back-EMF induced current crossover non-linearities are shifted away from normal listening voltage outputs. |
#409 |
Hi PMA.
Yes, every circuit introduces a delay. The same delay that can fail to prevent a NFB loop controlled class-AB amplifier output stage from damping loudspeaker back-EMF due to an inability for a VAS to reverse output drive. Output stages store charges and these must be actively removed, but the control response is finite, thus the development of 'crossover distortion'. |
#410 |
So called "back EMF" issue can be completely described by speaker electrical equivalent circuit. "Back EMF" is just exchange of energy between amplifier and parallel resonant circuit, representing acoustical impedance of speaker in the enclosure transferred to speaker terminals by electro-acoustic transformation.
