Some time ago I heard about this cheap headphone amp that could be modded to sound good. So I bought one and ordered some components. In its original state it sounds crappy to say the least.
What I've done: * Capacitors are now all Black Gate * resistors are now all Kiwame carbonfilm. * Op-amp is at the moment AD827, but can easily be changed since I've soldered on a socket on the PCB. * Volyme pot is now ALPS Blue Velvet. * the tone control and components around it has been put where they belong, the trash bin. * Diode is now BYV27-200 decoupled with a 0,1uF Wima capacitor. What I'm going to do: * Put decoupling caps on all BG's * Put decoupling cap on the op-amp. * Put in better RCA's * Use teflontube insulated silverwire as internal cable. * Raise bias to about 6,8mA and put a small heatsink on the op-amp if needed. * try a few other op-amps, I've got AD8066 and an adapterplate. Any input? I think that's all I can do to tweak this headphone amplifier. BTW, not sure if this is the right part of the forum to post this, if not a moderator could please move it. Sorry about the crappy english |
#2 |
I've got a broom. I've had it for years and years. It's had four handles and three heads. Its the best broom I've ever owned.
BT928? A bit modified? You've kept the PCB and the connectors... My friend gave me a Ferrari once. Well, it was a Renault, but he'd pinched the fuses from a Ferrari... Sorry if this comes across as negative, but really!
Overlord of the stuffed attic. |
#3 |
I really don't get the point of that post?!? What is it that you wish to say with it?
#4 |
As I said, it may seem negative (damn, it IS negative!) but, like you, I don't see the point.
You haven't, in any real sense, tweaked this amplifier - you've rebuilt it! I'm sure if you started from fresh, and looked around, you could build a better amplifier from scratch. Why start with a cheap-and-cheerful amplifier and then replace everything that made it cheap - IE almost everything? The whole point of finding cheap-and-cheerful pearls is to (maybe) give them a little polish, and then sit back and enjoy. Making the pearls into a diamond is pointless IMHO - why not buy (or build) a diamond from the beginning? You've put a lot of work into your amplifier, and I'm sure you're enjoying it - but I don't see the point. Sorry.
#5 |
That's ok, everyone has their own opinion, no need to be sorry.
#6 |
I hope my negativity isn't catching - You continue doing what you enjoy doing.
I'll continue collecting schematics, ordering bits and pieces, and changing my mind before I actually build anything at all... I'm glad I've not upset you too much - as you say, our opinions are just that - and all have equal validity. Happy building/tweaking. Steve.
#7 |
| Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 | tyler477 | Solid State | 1 | 31st October 2008 04:24 AM |
| Vancouver BC Tech? | lpd | Swap Meet | 0 | 2nd March 2007 09:31 PM |
| New Person...Old Tech. | Bentron | Introductions | 10 | 12th January 2006 03:09 PM |
| You Be the Tech | triodesteve | Pass Labs | 6 | 9th March 2004 01:42 PM |
| Page generated in 0.08789 seconds (80.94% PHP - 19.06% MySQL) with 10 queries |
