I just received a dead Sony Amp of the mid90's that's two generations younger than the 210 i already own. As the 210 has sort of an inbuild failure of two 2.2ohm resistors, I thought i could fix the 270 very easy.
No, it is a complete redesign and my service manual of the 210 doesn't fit to it at all :-( Very very obvious one channel has burned out, without having measured anything, all flameproof resistors in one channel have blackened the pcb so i assume both driver and power transistors are gone. However, one of the drivers is not available anymore: Sa1684 from NEC. What can i use as a spare? Does anyone have a SM of the 170/270 Sony TA-F lying around - where to measure the bias??? My older 210 has two tp connectors for that, this one ain't... The Sony uses: SA988 / SA1684 + SC4431 + SD2012 / 2SA1491 - 2SC3855 http://www.listmember.de/diyaudio/ta...esistorbbq.jpg |
#2 |
Cmon folks, I know you can help
| Connector Availability | diydummy | Parts | 25 | 19th December 2007 02:15 PM |
| Tube availability: what would you do? | bradd | Tubes / Valves | 6 | 27th February 2006 12:40 AM |
| CS8412 availability in UK | pinkmouse | Digital Source | 15 | 22nd August 2004 06:12 PM |
| MDF availability | Doug | Everything Else | 2 | 24th July 2003 12:04 PM |
| Slide Pot availability | vpharris | Parts | 0 | 7th February 2002 06:12 PM |
| Page generated in 0.07585 seconds (62.63% PHP - 37.37% MySQL) with 10 queries |
