Definition of Class G and Class H
Old 16th January 2007, 05:35 AM   #1
Gold_xyz is offline Gold_xyz  Italy
Gold_xyz's Avatar
Default Definition of Class G and Class H
Hallo !
The perfect definition of Class G and class H is hard to find...
http://www.diyaudio.com/forums/showt...threadid=68415
http://www.diyaudio.com/forums/showt...935&highlight=
I have this good document found :
http://www.rane.com/par-a.html
My English originates from here
Old 16th January 2007, 11:04 AM   #2
Workhorse is offline Workhorse
Workhorse's Avatar
Hello GOLD_XYZ,
In your diagram you shown the waveforms associated with the working of classes is wrong......
Class-H has Square Step Envelope....
While
Class-G has Linear Step Envelope
This is the correct one....
K a n w a r
Old 16th January 2007, 09:05 PM   #3
Bob Cordell is offline Bob Cordell  United States
Originally posted by Workhorse
Hello GOLD_XYZ,
While
K a n w a r
I believe that the US and Japanese definitions of Class G and Class H are swapped.
I can never keep track of it myself. I think Duncan covered it in his book.
I worked on the Crest 8001, which had three sets of rails. The upper rails moved in an analog fashion (they were not hard-switched). Crest referred to their amplifier as Class H.
Bob
Old 17th January 2007, 06:41 AM   #4
Gold_xyz's Avatar
Hello GOLD_XYZ,
While
K a n w a r
Hi Kanwar
I know well what you say.
In this site it says (class H) "electronic switching between multiple rail voltage levels"
http://ieeexplore.ieee.org/xpl/freea...&isnumber=3398
the problem is that in many sites he is otherwise written..
it says
"class G = rail switcher, class H = rail-tracker"
also wikipedia
http://en.wikipedia.org/wiki/Electronic_amplifier
and many others...
http://www.pcmag.com/encyclopedia_te...i=55350,00.asp
http://www.nfsa.afc.gov.au/glossary....r?OpenDocument
http://www.prg.com/support/education/glossary/audio/a
Bob
It would seem that there is need of a standard...
Old 17th January 2007, 07:27 AM   #5
Workhorse's Avatar
Originally posted by Gold_xyz
Hi Kanwar
it says
also wikipedia
and many others...
The STANDARD is well maintained as
Class-H = Square Step Envelope
Class-G = Linear Step Envelope
Class-TD= Rail Modulating Envelope...[Tracking Rail]
And stick to it as its Right.....
The other references are just an example of confused or misunderstood concepts...
regards,
K a n w a r
Old 19th January 2007, 07:10 AM   #6
Gold_xyz's Avatar
Hi, more news
...The first Class-G design into production by Hitachi
I need to find a schematics of "Dynaharmony HMA 8300 power amplifier"
I think that the first definition of the class H is with a multilevel switched supply... to see Pat. 3.319.175
In Soundcraftsmen MA5002 (Class-H) I see only a rail-tracking by Q19 - Q20 - Q21
http://www.soundcraftsmen.info/Class%20H/Amp%20AL.png
bye
Old 19th January 2007, 01:39 PM   #7
Workhorse's Avatar
Hi, more news
bye
If you look at the waveforms of Soundcraftsmen Class-h amp...they exhibit square step type envelope, not a linear envelope , therefore its Class-H
Old 20th January 2007, 08:30 AM   #8
Gold_xyz's Avatar
A little simulation with pspice of supply "lifter" of Soundcraftsmen MA5002 (Class-H)
this is undoubtedly a rail tracker...
and Pspice schematics..
Old 20th January 2007, 09:13 AM   #9
Gold_xyz's Avatar
...I mean to say in simple words "The Rail Switcher Amp" benefits from the elimination of wasted heat incase of class-AB , by splitting the power rails into 2 or 3 TIERS, and choosing the appropriate Rail according to the Voltage Swing at output.....So that the output transistor has less VCE across it to do the job with less wastage...
From : http://www.diyaudio.com/forums/showt...threadid=68415
Hi, Workhorse,
Your definition is right !
With two or more rail switcher (that approx. the envelope) or with a
rail tracker is a class H amplifier. (to see Pat. 3.319.175)
With a single rail switcher is a class G.
bye
Definition of Class G and Class HHide this!Advertise here!
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 11:25 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
What is the definition of Class A? Bricolo Solid State 6 18th November 2002 10:35 AM
Copyright ©1999-2017 diyAudio
