#21 |
dear friends hello!! i am from Greece and this is my first post in this website.
I would kindly like to ask for your help. In some days i am receiving my MF B200X from Germany. I have read your posts and also mr.henesis' website and i got excited. The problem is that i am not familiar with electronics, but i can find a friend who can solder. I have a friend who is an electrician. can you please write me in 2-3 lines what parts to order to "refresh" my amp. The parts that someone can easily change with a reasonable cost to revive this wonderfull amp. Thank you very very much in advance...i will be waiting for your answears. |
#22 |
www.darlas.gr will these be ok will they fit????
#23 |
The capacitors you've found will need a bit of work to fit, the originals are 25mm in diameter.
I just restored an B200 and the sound is great after setting the right quiescent current. Many thanks to Jez for helping. Parts used from Farnell: 4 x ESMH630VSN682MQ50T 2 x EEUFM1E221 4 x EEUFC1J101 4 x EEUFC1H100 1 x FAIRCHILD SEMICONDUCTOR - GBPC2504 - BRIDGE RECTIFIER, 25A, 400V Check for bad soldering, look for grainy/yellow/brown solder affected by heat. I resoldered 30-40% of the board. I would recommend PS capacitors with a greater voltage than 63V but I haven't found anything to fit. Good luck! |
| Musical Fidelity circuit diagram B200 | Paul318UK | Chip Amps | 1 | 5th July 2009 07:11 AM |
| musical fidelity b200 transformer | sakis | Solid State | 4 | 4th July 2009 09:04 PM |
| Music Fidelity B200 Circuit diagram | Paul318UK | Solid State | 0 | 4th July 2009 05:55 PM |
| musical fidelity B1 | mcberta2 | Solid State | 0 | 31st December 2007 10:31 AM |
| Musical Fidelity B200 (mosfet) rail volts? | mobyd | Solid State | 0 | 26th September 2005 04:39 AM |
| Page generated in 0.07367 seconds (72.00% PHP - 28.00% MySQL) with 10 queries |
