Distorting Accuphase E-302
Old 13th January 2007, 05:07 PM   #1
reins is offline reins  Germany
Default Distorting Accuphase E-302
one channel of the power amp is distorting audible.
Does anyone have schematic available?
As I think it might be difficult to get the schematic and I'm no expert in solid state amps, might it be helpful to measure the test points and compare the the two channels?
Is there any chance for me to find the bug?
Stephan
Old 13th January 2007, 10:11 PM   #2
Piercarlo is offline Piercarlo  Italy
Piercarlo's Avatar
Default Re: Distorting Accuphase E-302
Stephan
If you don't have much experience in troubleshooting it's a bit hard to try. However, having a channel working, comparing voltage as appearing in the same points of circuit may be a good idea but you *must* have a good background of typical circuits used in audio and a good ability to guess that specific circuit is employed in the section you are troubleshooting. Is not an impossible task but neither a easy one.
Hi
Piercarlo
Old 14th January 2007, 03:41 PM   #3
Default Re: Re: Distorting Accuphase E-302
Hi
Piercarlo
I fear that is true.
Even "worst", as the test points of both channels deliver nearly the same results.
But maybe its another problem (cables, relays, ..)?
Thanks,
Stephan
Old 15th January 2007, 08:19 AM   #4
Piercarlo's Avatar
Default Re: Re: Re: Distorting Accuphase E-302
That "nearly" must be evaluated. "Nearly" may be harmless if in the range of 0.5 or 1 volt but these differences may hide subtle malfunctioning of circuits. Once again, in absence of a schematic, a previous background of circuits which may be employed in typical audio equipment (for guessing some of that are really used) is mandatory.
Relay, especially if a bit weared-out by the years, are often the main causes of "crackling" amplifiers. You may beat their cases with the handle of a screwdriver and notice if something change. If the case, remove the covers and spray the relays with a suitable contact cleaner.
However, from other complaints i have eared, Accuphase (as many other industrial product builded with not-ever excellent PCB material) tend to suffer problems of cold solderings.
This may be a bit strange for someone because may be not easily understandable as a cold soldering which has well performed for years, suddenly cease to work. The key issues is "thermal stressing". Repeated cycles of warming-colding of equipment during the years, with alternate dilating and stretching of PCB materials (and components mounted on of course, included copper traces which are subject to be broken from this cycles, especially in section where an high thermal gradient is present, as typical in output stages with power devices directly soldered to the PCB) may easily conduct the equipment to these "strange" and "mysterious" fault.
Hi
Piercarlo
Old 16th January 2007, 06:07 AM   #5
Default Re: Re: Re: Re: Distorting Accuphase E-302
Hi
Piercarlo
That problem isn't new to me. My old Philips CD player suffers from that problem too. I'm still hunting hopefully the last sporadic malfunction there.
I thought: Not with Accuphase!
So I'll check for cold solder joins, maybe I have luck.
Stephan
Old 17th January 2007, 07:13 PM   #6
Super hint,
there where several suspicious looking solder joins on the amp board.
I have re-soldered them --->
And now the distortion is gone!
Stephan
Old 18th January 2007, 07:48 AM   #7
Piercarlo's Avatar
Super hint,
Stephan
Of nothing! My old crystal sphere seem to be a good one again!
Hi Piercarlo
Distorting Accuphase E-302Hide this!Advertise here!
Meridian MCD Distorting doarkface Digital Source 0 10th February 2009 07:47 PM
Distorting 5687 preamp circuit dsavitsk Tubes / Valves 13 14th June 2006 02:31 AM
Sub distorting - help please Simpleton Subwoofers 8 14th August 2005 06:56 AM
Mackie power amp distorting javey Solid State 2 20th April 2005 03:45 AM
Gainclone distorting in the higher frequencies jaume Chip Amps 9 26th March 2004 07:07 AM
Copyright ©1999-2017 diyAudio
