Quasi or not Quasi - that is the question
Old 13th January 2007, 02:42 PM   #11
Russ White is offline Russ White  United States
Russ White's Avatar
Kanwar,
The topology suits my goals, and in simulation (which should model the voltage drop correctly) I can easily go to within 2.5V of the rails. That does not seem like a huge loss to me.
As for the heat, I have no idea what you mean. The bias is not high enough to make much heat. It certainly will be cooler then my old Aleph 30.
Also, as a percentage, I doubt the people who make pro amps are in the majority of the forum users.
It seems you have some dislike for this output stage and you may have your reasons, but, as an amateur interested in hi-fi, I am going to have fun making it.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 13th January 2007, 03:32 PM   #12
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
To continue the topic I attach here a drawing of few different topologies. I've used MOSFETs throughout for simplicity . Top row - fully complementary output and a couple of quasi-complementary configurations. Bottom row - current sharing with P-ch splitter, N-ch splitter and differential P-ch pair as splitter. Last one is a well known option.
Alex
Old 14th January 2007, 07:29 AM   #13
quasi is offline quasi  Australia
quasi's Avatar
Default Re: Quasi or not Quasi - that is the question.
Umm....do I get to vote?
Cheers
Quasi
Old 14th January 2007, 07:48 AM   #14
Workhorse is offline Workhorse
Workhorse's Avatar
Default Re: Re: Quasi or not Quasi - that is the question.
Cheers
Quasi
Now he is Quasi himself, then what would you do Alex......
Old 14th January 2007, 10:55 AM   #15
x-pro's Avatar
Cheers
Quasi
Quasi, I knew you would not miss this thread. Please feel free to vote if you think it is the right way to solve this .
Cheers
Alex
Old 14th January 2007, 11:10 AM   #16
tschrama is offline tschrama  Netherlands
Can I vote for complementary?... Allthough I've allways had a soft spot for the quasi topologies nobody would even consider it if there would be a real perfect matched complementary transistors availeble.. or am I mistaken?
grzz, Thijs
ps let's stick to the original thread topic..
Old 14th January 2007, 11:27 AM   #17
x-pro's Avatar
grzz, Thijs
Hi Thijs,
yes, I suppose it is true. However the main question was - what to call "quasi" . In my view you can only use this word when you try to imitate a fully complementary topology with non-complementary devices. Otherwise we would call all valve amps and N-channel only amps with a transformer coupling also "quasi". Somewhere we should draw the line .
And it is true that there is no perfect complementary transistors in existance, especially bad the situation with MOSFETs as physics prohibits it. In any case two different structures would behave differently with current, temperature, transient power etc. even if they matched well in a particular point of characteristics. If you use two same devices and drive these symmetrically you can have symmetrical dynamic behavior and I consider that important in audio.
Cheers
Alex
Old 14th January 2007, 02:12 PM   #18
oops sorry,
Offcourse ...I agree... it comes down to how the output stage is driven... if the previous stage is such that it could drive a complementary output stage.. then the output stage is quasi-complementary...
in other words.. it the output stage can be sustituted by a complementairy output-pair.. without changes to the previous stage, the output stage can best be called quasi-complementary..
I like your output stage overview btw...
Old 14th January 2007, 02:22 PM   #19
x-pro's Avatar
oops sorry,
I can not agree with that definition . Any VAS can be coupled somehow to any output stage. What about a valve transformer output again? It can be happily driven by a conventional VAS. "Quasi-complementary" means "imitation-complementary", isn't it? If we "imitate" one of the devices in a fully complementary topology than it is "quasi", otherwise it is not.
Put it another way - in a "quasi-complementary" you always can without really changing the topology replace a part of the circuit with a complementary transistor to make it fully complementary. If you can not do it, than the circuit can not be called "quasi".
Cheers
Alex
Old 20th January 2007, 04:39 AM   #20
TomWaits is offline TomWaits  Canada
TomWaits's Avatar
Default More Quasi, please...
I would personally like to see the advancements of Mr. White’s & x-pro's indulgence on this work. I think if there is something good worth exploiting, they may find it.
I find it difficult to understand a persistent negative flow from critics and detractors but then again that is the true fuel to real discovery, even if it only results in a lesson learned.
Shawn.
Quasi or not Quasi - that is the questionHide this!Advertise here!
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 10:07 AM
