Quasi or not Quasi - that is the question - Page 4 - diyAudio
Old 10th October 2013, 10:50 AM   #31
AndrewT is online now AndrewT  Scotland
post12.
What is the difference between "current sharing" and Quasi complementary?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th October 2013, 04:25 PM   #32
Workhorse's Avatar
Originally Posted by AKSA View Post
Kanwar,
By ending up with different output impedances from each half, you force higher levels of H2 and H4. Put another way, this sounds a bit more warm.
Some people actually prefer a quasi amp over a complementary output stage.
But then you knew this already.....
Ciao
Hugh
Hello Hugh,
Long time no see ,
I tend to differ here, in the above examples given by Alex, the output impedances are highly balanced if compared to the usual quasi-complementary, because of the feedback. Also if the outputs are configured as VCCS then also you will have balanced case of impedences.
Correct me if i am wrong, but after having simulated the VCCS stage[my own version] in open loop, i am not getting H2 which is higher than H3.
Originally Posted by AndrewT View Post
post12.
In the current sharing figure: The Drain of Lower output mosfet makes connection with the Source of P-channel input driver mosfet, which in a way provides local negative feedback and linearizes the full output stage.
Kanwar
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Copyright 1999-2017 diyAudio
